Epson EB-1945W LCD 4200 Lumens Projector
Quicklinx: 8MGCWS00 Mfr#: V11H471041
  • High-Definition Multimedia Interface (HDMI)
Convenient use
The Epson EB-1945W combines high-quality output, value-added features and affordability, into a compact and portable projector. It is perfect for corporate or educational use, as it can be easily installed in meeting rooms or used portably from a desktop.
High quality picture
Utilising Epson's 3LCD technology to ensure clearly projected images, the EB-1945W produces vivid, natural colours and an equally high White and Colour Light Output, even in daylight.
The EB-1945W boasts Wi-Fi connectivity and a DisplayPort connector, allowing you to show high definition audio and video content with ease.
Easy calibration
New to Epson is the convenient 'focus help' feature, which calibrates using a test pattern to allow any meeting room set up to be catered for quickly and easily. This process is made even easier with a wide controller manufacturer compatibility, so the EB-1945W can integrate into an existing system with ease. Also new to Epson is real time auto vertical and horizontal keystone correction, adjusting images in real time, with visible results in seconds. When used with the screen fit function, which corrects images to any framed screen within seconds, calibration of the EB-1945W is quick and simple.
Enhanced productivity
Productivity can be greatly increased with a range of features available with the EB-1945W, with the Multi-PC feature allowing content from up to four computers to be shown.
  • Auto correcting projector
    Affordable, compact and easily calibrated projection from a feature packed device.
Epson EB-1945W - 3LCD projector - 802.11g/n wireless / LAN
3LCD projector
Built-in Devices
Speaker
Ethernet, Fast Ethernet
Brightness
4200 lumens
Brightness (Colour)
4200 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Bulb type
E-TORL UHE 245 Watt
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11g/n wireless / LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI), DisplayPort
Video Modes
480p, 720p, 1080i, 1080p, 480i, 720i, 526i, 526p
Video Output
RGB
Speakers
Speaker(s) - integrated
337 Watt
37.7 cm x 10.8 cm x 27.1 cm
3.9 kg
3-year warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
4200 lumens
Brightness (Colour)
4200 lumens
Brightness (Reduced)
2910 lumens
Contrast Ratio
3000:1
Image Size
74 cm - 711 cm
Projection Distance
0.8 m - 13.9 m
Throw Ratio
1.38 - 2.24:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Display Format
1,024,000 pixels (1,280 x 800) x 3
Colour Support
Bulb type
E-TORL UHE 245 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Chinese, Korean
sRGB colour profile, freeze frame, Blackboard Mode, JPEG photo playback, USB host function, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, Split Screen, 16:10 aspect ratio support, DICOM Simulation Mode, Direct Power On, Direct Power Off, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video
Video Modes
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
Input Device
External
1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x DisplayPort - 20 pin DisplayPort , 1 x audio line-in - RCA x 2
USB wireless network adapter, wireless remote control
1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
337 Watt
Power Consumption Operational (Standby)
0.44 Watt
Software Included
Drivers & Utilities, EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
37.7 cm
10.8 cm
27.1 cm
3.9 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
5 °C
35 °C
20 - 80%
Sound Emission
37 dB
29 dB
8MGC C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
