Convenient use
The Epson EB-1945W combines high-quality output, value-added features and affordability, into a compact and portable projector. It is perfect for corporate or educational use, as it can be easily installed in meeting rooms or used portably from a desktop.
High quality picture
Utilising Epson's 3LCD technology to ensure clearly projected images, the EB-1945W produces vivid, natural colours and an equally high White and Colour Light Output, even in daylight.
The EB-1945W boasts Wi-Fi connectivity and a DisplayPort connector, allowing you to show high definition audio and video content with ease.
Easy calibration
New to Epson is the convenient 'focus help' feature, which calibrates using a test pattern to allow any meeting room set up to be catered for quickly and easily. This process is made even easier with a wide controller manufacturer compatibility, so the EB-1945W can integrate into an existing system with ease. Also new to Epson is real time auto vertical and horizontal keystone correction, adjusting images in real time, with visible results in seconds. When used with the screen fit function, which corrects images to any framed screen within seconds, calibration of the EB-1945W is quick and simple.
Enhanced productivity
Productivity can be greatly increased with a range of features available with the EB-1945W, with the Multi-PC feature allowing content from up to four computers to be shown.
Auto correcting projector
Affordable, compact and easily calibrated projection from a feature packed device.
- Epson EB-1945W - 3LCD projector - 802.11g/n wireless / LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet, Fast Ethernet
- Brightness
- 4200 lumens
- Brightness (Colour)
- 4200 lumens
- Contrast Ratio
- 3000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Bulb type
- E-TORL UHE 245 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11g/n wireless / LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI), DisplayPort
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 720i, 526i, 526p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 337 Watt
- 37.7 cm x 10.8 cm x 27.1 cm
- 3.9 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Data Link Protocol
Projector
- Brightness
- 4200 lumens
- 4200 lumens
- Brightness (Reduced)
- 2910 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 74 cm - 711 cm
- Projection Distance
- 0.8 m - 13.9 m
- Throw Ratio
- 1.38 - 2.24:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Display Format
- 1,024,000 pixels (1,280 x 800) x 3
- Colour Support
- Bulb type
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Chinese, Korean
- sRGB colour profile, freeze frame, Blackboard Mode, JPEG photo playback, USB host function, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, Split Screen, 16:10 aspect ratio support, DICOM Simulation Mode, Direct Power On, Direct Power Off, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x DisplayPort - 20 pin DisplayPort , 1 x audio line-in - RCA x 2
- Included Accessories
- USB wireless network adapter, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
- Voltage Required
- 337 Watt
- Power Consumption Operational (Standby)
- 0.44 Watt
- Software Included
- Drivers & Utilities, EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 10.8 cm
- 27.1 cm
- 3.9 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
