Epson EB-1780W 3,000 lumens, WXGA, 3LCD Wi-Fi
Quicklinx: D605WS00 Mfr#: V11H795041
Portability: Portable
£737.84 ex VAT
£885.40 inc VAT
Exceptional image quality
Enjoy superb image quality, impressive natural colours with an equally high white and colour light output of 3,000 lumens thanks to Epson's 3LCD technology. True Colours technology delivers a faithful reproduction of colours as they are meant to be and, with a 10,000:1 contrast ratio, projected images are crisp and clear.
Easy set-up
Automatic vertical and horizontal keystone correction makes it easy to set up the projector almost anywhere. The short throw ratio projects a large image from a shorter distance so that all meeting participants can be seated behind the projector as the front exhaust directs heat away from them. Thanks to its Auto Power On feature, the projector turns on when it detects signal input.
Smarter presentations
Users can view two data sources side by side with split screen, and MHL can show high-quality video and audio content from mobile devices while charging them at the same time.
True portability
The ultra-slim form factor and lightweight design makes this the ideal projector for anyone on the move. A carry case is included and the projector fits easily into a standard laptop bag.
Epson EB-1780W - LCD projector - portable - 802.11n wireless / NFC / Miracast
LCD projector - 720p
Black, white
United Arab Emirates, United Kingdom
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
206 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, composite video IEEE 802.11n wireless / NFC / Miracast
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified Projectors 2
AC 120/230 V (50 - 60 Hz)
277 Watt
29.2 cm x 21.3 cm x 4.4 cm
1.77 kg
802.11b/g/n, NFC
Enclosure Colour
Black, white
Projector
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Brightness (Reduced)
1900 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 8.2 m
Throw Ratio
1.04 - 1.26:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
206 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.7
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, NFC (Near Field Communication), Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x composite video input - RCA
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
TCO Certified
Power Source
AC
Nominal Voltage
277 Watt
Power Consumption Stand by
0.34 Watt
Software Included
EasyMP Multi PC Projection
29.2 cm
21.3 cm
4.4 cm
1.77 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
30 dBA
Brand: Epson
Price Range Ex VAT: 500 - 750
