Epson EB-1771W LCD 3000 Lumens Projector
Quicklinx: 8MG0WS00 Mfr#: V11H477041
Ultra-mobile, extra-flat: With a lightweight, slimline design, presenting on the move has never been easier. Weighing just 1.7kg, this is the ideal projector choice for anyone travelling to meetings.
Get a wider picture: See more of the presentation with the WXGA resolution. Ideally suited to spreadsheets and data, audiences will see everything displayed on a widescreen computer as this format offers 30% more pixels than XGA alternatives.
First-class picture quality: Audiences will enjoy perfect picture quality, impressive natural colours and brightness of 3,000 lumens white and Colour Light Output, thanks to Epson's 3LCD technology.
Speedy start-up: Simple to set up with features such as quick-start and instant-off, slides and images can be aligned and distortion corrected with the projector's automatic vertical and manual horizontal keystone correction.
Enhance your presentation: Control and improve presentations with a host of Easy MP features, including 3-in-1 USB display - compatible with Macs as well as PCs - and USB PC-free functionality.
Go wireless: With the option of high-speed Wi-Fi functionality, setting up a presentation is a smooth, simple process minus the bother of cables.
  • Ultra-mobile projector with WXGA resolution
    Lightweight, bright and offering exceptional picture quality, this extra-flat WXGA projector displays a bigger image as well as offering optional wireless connectivity.
Epson EB-1771W - 3LCD projector - portable
3LCD projector
Brightness
3000 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
UHE 230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Speakers
Speaker(s) - integrated
304 Watt
29.2 cm x 21 cm x 4.4 cm
1.7 kg
3-year warranty
3LCD projector
Projector
Brightness
3000 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 8.2 m
Throw Ratio
1.04 - 1.26:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
UHE 230 Watt
Bulb life cycle
Controls & Adjustments
Mute
OSD Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan
sRGB colour profile, freeze frame, Blackboard Mode, JPEG photo playback, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.7
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
1080p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B
Carrying case, wireless remote control
1 x VGA cable - 1.8 m , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
304 Watt
Power Consumption Operational (Standby)
0.4 Watt
Software Included
EasyMP Network Projection
29.2 cm
21 cm
4.4 cm
1.7 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
Sound Emission
40 dB
30 dB
8MG0 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
