Ultra-mobile, extra-flat: With a lightweight, slimline design, presenting on the move has never been easier. Weighing just 1.7kg, this is the ideal projector for anyone travelling to meetings.
First-class picture quality: Audiences will enjoy perfect picture quality, natural colours and brightness of 2,600 lumens white and Colour Light Output thanks to Epson's 3LCD technology.
Get a wider picture: See more of the presentation with the WXGA resolution. Ideally suited to spreadsheets and data, audiences will see everything displayed on a widescreen computer as this format offers 30% more pixels than XGA.
Speedy start-up: Simple to set up with features such as quick-start and instant-off, slides and images can be aligned and distortion corrected with the projector's automatic vertical and manual horizontal keystone correction.
Enhance your presentation: Control and improve presentations with a host of Easy MP features, including 3-in-1 USB display - compatible with Macs as well as PCs - and USB PC-free functionality.
Go wireless: With the option of high-speed Wi-Fi functionality, setting up a presentation is a smooth, simple process minus the bother of cables.
Ultra-mobile business projector
An ultra-mobile WXGA projector with Epson's 3LCD technology, 2,600 lumens white and Colour Light Output, plus a host of easy set-up features.
- Epson EB-1761W - 3LCD projector - portable
- 3LCD projector
- Brightness
- 2600 lumens
- Brightness (Colour)
- 2600 lumens
- Contrast Ratio
- 2000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- UHE 205 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 1080p
- Speakers
- Speaker(s) - integrated
- 278 Watt
- 29.2 cm x 21 cm x 4.4 cm
- 1.68 kg
- 3-year warranty
- 3LCD projector
Projector
- Brightness
- 2600 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.7 m - 8.2 m
- Throw Ratio
- 1.04 - 1.26:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- UHE 205 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan
- Auto Vertical Keystone, EPSON 3LCD technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.7
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- 1080p
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- 278 Watt
- Power Consumption Operational (Standby)
- 0.44 Watt
- 29.2 cm
- 21 cm
- 4.4 cm
- 1.68 kg
- Limited warranty - 3 years
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 30 dBA
