Your basket is empty
Epson EB-1761W LCD 2600 Lumens Projector
Quicklinx: 8MFXWS00 Mfr#: V11H478041
Ultra-mobile, extra-flat: With a lightweight, slimline design, presenting on the move has never been easier. Weighing just 1.7kg, this is the ideal projector for anyone travelling to meetings.
First-class picture quality: Audiences will enjoy perfect picture quality, natural colours and brightness of 2,600 lumens white and Colour Light Output thanks to Epson's 3LCD technology.
Get a wider picture: See more of the presentation with the WXGA resolution. Ideally suited to spreadsheets and data, audiences will see everything displayed on a widescreen computer as this format offers 30% more pixels than XGA.
Speedy start-up: Simple to set up with features such as quick-start and instant-off, slides and images can be aligned and distortion corrected with the projector's automatic vertical and manual horizontal keystone correction.
Enhance your presentation: Control and improve presentations with a host of Easy MP features, including 3-in-1 USB display - compatible with Macs as well as PCs - and USB PC-free functionality.
Go wireless: With the option of high-speed Wi-Fi functionality, setting up a presentation is a smooth, simple process minus the bother of cables.
Epson EB-1761W - 3LCD projector - portable
3LCD projector - High Definition
Brightness
2600 lumens
Brightness (Colour)
2600 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
UHE 205 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Speakers
Speaker(s) - integrated
278 Watt
29.2 cm x 21 cm x 4.4 cm
1.68 kg
3 years warranty
3LCD projector - HD
Projector
Brightness
2600 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 8.2 m
Throw Ratio
1.04 - 1.26:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
UHE 205 Watt
Bulb life cycle
OSD Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan
Auto Vertical Keystone, EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.7
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
1080p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B
Carrying case, wireless remote control
1 x VGA cable - 1.8 m , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection
278 Watt
Power Consumption Operational (Standby)
0.44 Watt
29.2 cm
21 cm
4.4 cm
1.68 kg
Limited warranty - 3 years
Sound Emission
37 dBA
30 dBA
8MFX C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
8MFX C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.73
8MFX C2G 5m Select High Speed HDMI with Ethernet In Stock £15.61
8MFX C2G 10m Select High Speed HDMI with Ethernet In Stock £29.98
8MFX C2G 15m Select High Speed HDMI with Ethernet In Stock £40.60
8MFX C2G Pro HDMI to VGA Converter In Stock £46.06
