Epson EB-1460Ui 4400 Lumens WUXGA 3LC Ultra Short Throw Projector
Quicklinx: CVY7WS00 Mfr#: V11H726041
Type: WXGA projector
Brightness: 4400ANSI lumens
Contrast Ratio: 16000: 1
Portability: Non-portable
Hurry, only 1 left in stock!
£2,596.36 ex VAT
£3,115.63 inc VAT
Bring interactivity to any meeting room with our latest ultra-short-throw projector, featuring finger-touch and dual pen capability, a high brightness level of 4,400 lumens, Full HD WUXGA resolution and remote multi-location connectivity. The ultra-short-throw EB-1460Ui is designed to present a scalable screen size of up to 100 inches to deliver the requirements of any business working environment.
Up to 100-inch display and outstanding quality
Full HD WUXGA resolution combined with Epson’s 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity also means that the audience benefits from sharper and clearer content displayed in any meeting room environment.
All in one office solution
This interactive meeting room solution combines the benefits of flipcharts, whiteboards and conventional screens into one unified meeting room solution. Meeting participants can view and annotate whiteboard content from a range of smart devices, without the need for any special application and this ensures information remains secure with the ability to apply passwords to meetings and notes.
Finger-touch and dual pen
Use your fingers to annotate directly on the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, colleagues can work simultaneously using different pen attributes.
Sliding split screen
Combine two sources and project, such as multi-source video conference and presentation, to optimise interaction.
Wireless & Screen Mirroring connectivity
Share content easily from a range of smart devices using the iProjection App and screen mirroring feature. The same content can be annotated remotely, with up to four networked projection systems connected at the same time.
Epson EB-1460Ui - 3LCD projector - 802.11b/g/n wireless / LAN / Miracast
3LCD projector - 1080p
White
Built-in Devices
Speaker
Brightness (White)
4400 lumens
Brightness (Colour)
4400 lumens
Contrast Ratio
300:1 / 16000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Video Input
RGB, S-Video IEEE 802.11b/g/n wireless / LAN / Miracast
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified Projectors 2
AC 230V (50 - 60 Hz)
490 Watt
47.4 cm x 44.7 cm x 13 cm
8.5 kg
3-year warranty
Built-in Devices
Speaker
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
4400 lumens
Brightness (Colour)
4400 lumens
Brightness (Reduced)
2700 lumens
Contrast Ratio
Image Size
178 cm - 254 cm
Projection Distance
0.4 m - 0.6 m
Throw Ratio
0.27 - 0.37:1
Digital Zoom Factor
1.35x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode, Auto Calibration
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
RGB, S-Video
Video Interfaces
VGA, HDMI, S-Video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out , 1 x DVI-D output
Wireless remote control, control pad, pen case, finger touch unit, interactive pens
1 x USB cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection
TCO Certified
Power Source
AC
Nominal Voltage
490 Watt
Power Consumption Stand by
0.5 Watt
Software Included
Epson Easy Interactive Tools, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
47.4 cm
44.7 cm
13 cm
8.5 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
38 dBA
30 dBA
Brand: Epson
Price Range Ex VAT: 1500+
