Quality image
Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitor products . HDMI inputs mean that meeting participants benefit from sharp, clear projected images. With up to a 100-inch screen-size, a multi-source video conference and presentation can be displayed in split-screen, without compromising on image size.
Finger-touch and dual pen
Use your fingers to annotate directly onto the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens,colleagues can work simultaneously using different pen attributes.
More control and collaboration
This interactive meeting room system combines the roles of ultra-short-throw projectors, interactive whiteboards and paper flipcharts in one multi-purpose, integrated product. The new whiteboard sharing mode allows meeting participants to view and annotate whiteboard content from a range of smart devices, without the need for any special application.
Finger-touch meeting room system
This interactive, ultra-short-throw, business projector is ideal for inspiring collaboration and transforming any meeting room.
- Epson EB-1430Wi - 3LCD projector - ultra short-throw - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness (White)
- 3300 lumens
- Brightness (Colour)
- 1900 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Lens
- Ultra short-throw fixed lens
- Bulb type
- 245 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 365 Watt
- 36.7 cm x 37.5 cm x 15.5 cm
- 5.7 kg
- 2-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- 3300 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 152 cm - 254 cm
- Projection Distance
- 0.4 m - 0.6 m
- Throw Ratio
- 0.27:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- 245 Watt
- Bulb life cycle
- sRGB colour profile, EPSON 3LCD technology, Whiteboard Mode, Split Screen, 16:10 aspect ratio support, Direct Power On, Direct Power Off, Dynamic Lamp Control, Dynamic Mode, Theater Mode, MHL compliance, Auto Calibration
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.8
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- RGB, S-Video
- Video Interfaces
- VGA, HDMI, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x S-video input , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C (management) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x remote control
- Included Accessories
- Wall mounting kit, Interactive Pen, pen tray, 2 Interactive Pens, remote control, control pad, finger touch module
- Cables Included
- 1 x USB cable
- Mounting Kit
- Included
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Voltage Required
- 365 Watt
- Power Consumption Stand by
- 0.42 Watt
- 36.7 cm
- 37.5 cm
- 15.5 cm
- 5.7 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 28 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
