Epson DLQ 3500 Colour Dot-Matrix Printer
Quicklinx: 65P7WS00 Mfr#: C11C396086
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Dot-matrix
£1,311.80 ex VAT
£1,574.16 inc VAT
This durable, counter top, flatbed, 24 pin dot matrix printer is ideal for high volume requirements, producing crisp clear output every time. The Epson DLQ-3500 is exceptionally economical to run and is ultra reliable across all stationery types.
  • Ultra reliable, high speed, high volume printing
    This durable, counter top, flatbed, 24-pin dot matrix printer is ideal for high volume requirements, producing crisp clear output every time. The Epson DLQ-3500 is exceptionally economical to run and is ultra reliable across all stationery types.
  • Versatile paper handling
    The ergonomic design offers three-way paper handling - front, rear and top, and the straight, flat paper path are perfect for multi-part stationery. It's even capable of handling paper of varying thicknesses, as well as overlapping and forms with labels.
  • Ease of use
    It features automatic platen gap adjustment for optimized print quality and optimized paper feeding - ideal for those who regularly alternate between different paper types. An optional sheet alignment unit automatically straightens single and multi-part cut sheet paper before printing - for less user intervention, speedier paper loading and accurate print alignment on forms.
  • Color printing
    Supplied with both black and color fabric ribbons for enhanced functionality.
Epson DLQ 3500 - printer - colour - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - colour
18.1 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Print Speed
Up to 550 char/sec - draft , Up to 594 char/sec - max speed , Up to 495 char/sec - draft , Up to 165 char/sec - letter , Up to 198 char/sec - letter
Parallel, USB
RAM Installed (Max)
128 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Microsoft Certification
Works with Windows Vista
1-year warranty
66 cm x 43.2 cm x 27.6 cm
Printer Type
Printer
Print Speed
Up to 550 char/sec - draft - 10 cpi , Up to 594 char/sec - max speed - 12 cpi , Up to 495 char/sec - draft - 10 cpi , Up to 165 char/sec - letter - 10 cpi , Up to 198 char/sec - letter - 12 cpi
Wired
Parallel, USB
Fonts Included
10 x bitmapped , 4 x scalable , 8 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Media Sizes
A3 (297 x 420 mm)
Max Sheets in Multi-Part Form
8
1 x parallel , 1 x USB
MTBF
10,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Limited warranty - 1 year
Sound Emission (Operating)
59 dBA
66 cm
43.2 cm
27.6 cm
18.1 kg
Type: Printer
Output Type: Colour
Max Print Speed: [N/A]
Max Paper Size: A3 (297 x 420 mm)
Brand: Epson
Price Range Ex VAT: 1000 - 1500
