As the only company in the world to design, develop and market both inkjet printers and industrial precision robotics, it makes perfect sense for us to combine the two. The result is the Discproducer - photo-realistic printing and fully automated CD/DVD reproduction in one neat package.
Super-productive and hassle-free
As easy to use as an office printer, the Discproducer can output up to 100 CDs/DVDs in a single session. Depending on data type and volume that amounts to up to 30 units per hour. It's the only product in its class that has front facing control and status reporting.
The best print quality in its class
You'll get vibrant, lifelike, razor sharp prints that are smudgeproof and water resistant thanks to the advanced print technology and ink. Media from other manufacturers can be used.
Cost-effective to own
Incredibly, you can produce over 1,000 prints per set of ink cartridges. And because it uses a separate cartridge for each colour, you only need to change the cartridges that are near empty.
Full network capability
Reducing load on your network, the PP-100N can manage the jobs of multiple users simultaneously. -
Built-in control board
Up to 120 jobs can be stored on the internal hard drive. -
Internal harddrive
The latest jobs can be retrieved and reproduced at any time. -
6-colour micro piezo
Vibrant, high-quality disc printing.
- Epson Discproducer PP-100N - DVD duplicator - Gigabit Ethernet - external
- DVD duplicator - external
- Interface
- Gigabit Ethernet
- Removable Media Capacity
- 100
- 37.7 cm x 51.4 cm x 34.8 cm
- 25 kg
- Optical Storage
- 2 x DVD+RW (double layer)
- Write Speed
- 40x (CD) / 12x (DVD)
- 1-year warranty
- Interface
- Gigabit Ethernet
- 100
- Built-in Devices
- Printer, status LCD
- 37.7 cm
- 51.4 cm
- 34.8 cm
- 25 kg
Optical Storage
- Write Speed
- Supported Media Types
- CD-R, DVD-R, DVD+R, DVD+R DL
Hard Drive
- Standard - internal
Printer
- Printing Technology
- Ink-jet
- Output Type
- 1 x Ethernet 1000 - RJ-45
- Software Included
- Epson Total Disc Maker
- OS Required
- Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Server 2012 (32/64-bits)
- Limited warranty - 1 year - on-site
