Epson DFX 9000N Mono Dot-Matrix Printer
Quicklinx: 5JLYWS00 Mfr#: C11C605011A5
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Dot-matrix
£3,614.28 ex VAT
£4,337.13 inc VAT
The Epson DFX-9000 is a high print volume printer providing an unprecedented level of speed and reliability for the most demanding business. Its advanced paper handling accommodates a variety of paper types while the standard front and rear push tractors can be switched easily between different types of continuous paper. An optional perforation cutter provides paper finishing capabilities.
Epson DFX 9000N - printer - B/W - dot-matrix
Printer Type
Personal printer - dot-matrix - 9 pin - B/W
34 kg
Max Media Size
Continuous paper 76.2 mm - 419.1 mm (width)
Max Media Size (Custom)
419 mm
Print Speed
Up to 1550 char/sec - max speed , Up to 1450 char/sec - max speed , Up to 1320 char/sec - draft , Up to 1320 char/sec - draft , Up to 330 char/sec - near letter , Up to 330 char/sec - near letter
Max Resolution (B&W)
240 x 144 dpi
Parallel, USB, LAN, serial
RAM Installed (Max)
128 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Labels, continuous forms
Print server - Ethernet, Fast Ethernet
AC 120/230 V
Microsoft Certification
Works with Windows Vista
1-year warranty
70 cm x 37.8 cm x 36.3 cm
Printer Type
Personal printer - dot-matrix - 9 pin - monochrome
Printer
Print Speed
Up to 1550 char/sec - max speed - 10 cpi , Up to 1450 char/sec - max speed - 12 cpi , Up to 1320 char/sec - draft - 10 cpi , Up to 1320 char/sec - draft - 12 cpi , Up to 330 char/sec - near letter - 10 cpi , Up to 330 char/sec - near letter - 12 cpi
Wired
240 x 144 dpi
Columns
136
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
419 mm
Max Sheets in Multi-Part Form
10
Print server
Expansion Slots
1 x Epson Type B
1 x serial , 1 x parallel , 1 x USB , 1 x LAN - RJ-45
MTBF
20,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
CISPR 22 Class B, EN 60950, EN 61000-3-2, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, FCC Part 15 B
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
185 Watt
Power Consumption Stand by / Sleep
7.5 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
Sound Emission (Operating)
58 dBA
70 cm
37.8 cm
36.3 cm
34 kg
Resources
The following resources are available for the Epson DFX 9000N Mono Dot-Matrix Printer
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Continuous paper 76.2 mm - 419.1 mm (width)
Brand: Epson
Price Range Ex VAT: 1500+
