Product
Epson ColorWorks TM-C7500 Industrial Colour DURABrite Ultra Inkjet Label Printer
Quicklinx: BB8XWS00 Mfr#: C31CD84012
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Ink-jet
£6,087.17 ex VAT
£7,304.60 inc VAT
Reliable and consistent results{b
}The C7500 can help manufacturers produce consistent, high-quality labels in-house and on-demand. The printer features the new PrecisionCore printhead to ensure reliable, high-quality results. Our unique Nozzle Verification Technology (NVT) and dot substitution help prevent misprints and dead pixels for consistent printouts.{b
}Fast speeds{b
}Produce a range of high-quality labels, fast including those for food and beverage products, packaging and boxes, as well as EU Energy Labels and GHS Labels. With print speeds of up to 300mm/sec, you can now print labels in full colour, at the same speed as some incumbent thermal monochrome printers.{b
}{b
Cost-effective}{b
}Printing labels on-demand helps eliminate costs associated with pre-printing, such as label waste and large label inventory. High-capacity, individual ink cartridges mean only the colour used will need to be replaced, offering very low cost per print. The permanent printhead offers significant cost savings, and a guaranteed peace of mind as none of its major components will need replacing for at least 500km worth of printing┬╣.{b
}Easy to use with minimal maintenance{b
}With its LCD control panel, set-up is easy. Our newest printer command set, ESC/Label, allows integration with virtually any operating system. The device also comes with a full range of software utilities to support printer deployment. NVT also helps to prevent clogged nozzles.
  • Industrial colour label printer
    Produce high-quality colour labels in-house and on-demand with this reliable and cost-effective industrial printer.
Epson ColorWorks TM-C7500 - label printer - colour - ink-jet
Printer Type
Label printer - ink-jet - colour
36.7 kg
Inkjet Technology
Epson PrecisionCore TFP
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Max Media Size
Continuous paper 50 mm - 112 mm (width)
Min Media Size (Custom)
50 mm
Max Media Size (Custom)
112 mm
Print Speed
Up to 300 mm/sec - 108 mm width
Max Resolution (B&W)
600 x 1200 dpi
USB 2.0, Gigabit LAN
Media Type
Labels, continuous paper labels, die cut labels
Black Mark sensor
Print server
AC 120/230 V
39.2 cm x 59.8 cm x 39.7 cm
Printer Type
Printer
Inkjet Technology
Nozzle Configuration
600 nozzles (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Ultra inks
Print Speed
Up to 300 mm/sec - 600x1200 dpi - 108 mm width
Built-in Devices
Status LCD
Wired
600 x 1200 dpi
Black Mark sensor
Auto Cutter
Media Handling
Media Type
Max Media Size
50 mm
112 mm
Media Sizes
Max Printing Width
108 mm
Roll Maximum Outer Diameter
203.2 mm
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
1 x USB cable
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (yellow) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x maintenance box
Media Included
Roll of media
Power supply - internal
AC 120/230 V
Frequency Required
50 - 60 Hz
86 Watt
Power Consumption Stand by
4 Watt
5 °C
35 °C
20 - 80%
39.2 cm
59.8 cm
39.7 cm
36.7 kg
Width (Shipping)
57.5 cm
Depth (Shipping)
79.3 cm
Height (Shipping)
54 cm
Weight (Shipping)
44 kg
Type: Printer
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Brand: Epson
Price Range Ex VAT: 1500+
