Flexible and expandable: The AcuLaser M2400D series has the flexibility to perfectly match the needs of your workgroups and desktop users, with expandable RAM from 32MB up to 320MB. Paper handling is adjustable too, with automatic double-sided printing and a choice of one or two optional additional paper trays to increase capacity to 800 sheets.
Easy compatibility: Seamlessly integrating into most IT environments, the AcuLaser M2400D series supports PCL5e, PCL6, standard ESC/Page, FX, ESCP2, 1239X, Genuine PostScript 3TM and PDF 1.3. It also features a parallel port (D model) or an Ethernet interface (DN model) for easy connectivity.
Lower costs and environmental impact: Your company's cost per page is optimised with a choice of standard and high-capacity toner cartridges. The AcuLaser M2400D series' ENERGY STAR qualified power efficiency and Epson's toner cartridge return programme further reduce bills and minimise environmental impact.
Model configuration:
C11CB47071 Epson AcuLaser M2400D - Main model
C11CB47071BY Epson AcuLaser M2400DT 220v - Main Model + one additional paper tray
C11CB47101 Epson AcuLaser M2400DN - Main model
C11CB47101BY Epson AcuLaser M2400DTN 220v - Main Model + one additional paper tray.
The AcuLaser M2400D series has the flexibility to perfectly match the needs of your workgroups and desktop users, with expandable RAM from 32MB up to 320MB. Paper handling is adjustable too, with automatic double-sided printing and a choice of one or two optional additional paper trays to increase capacity to 800 sheets. -
Easy compatibility
Seamlessly integrating into most IT environments, the AcuLaser M2400D series supports PCL5e, PCL6, standard ESC/Page, FX, ESCP2, 1239X, Genuine PostScript 3 and PDF 1.3. It also features a parallel port (D model) or an Ethernet interface (DN model) for easy connectivity. -
Your company’s cost per page is optimised with a choice of standard and high-capacity toner cartridges. The AcuLaser M2400D series’ ENERGY STAR qualified power efficiency and Epson’s toner cartridge return programme further reduce bills and minimise environmental impact.
- Epson AcuLaser M2400DT - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 11.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - monochrome - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- Parallel, USB
- Processor
- 300 MHz
- RAM Installed (Max)
- 32 MB (288 MB)
- Language Simulation
- PCL 5E, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P
- Total Media Capacity
- 550 sheets
- Media Handling
- 50-sheet multipurpose tray, 2x 250-sheet paper cassette
- Monthly Duty Cycle (max)
- 50000 pages
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Apple MacOS X 10.4.11 or later, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- 1-year warranty
- 37.8 cm x 39 cm x 25.5 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 7 sec
- Media Handling
- Processor
- 300 MHz
RAM
- 32 MB / 288 MB (max)
Media Handling
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), F4
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 550 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) , 2 x automatic - 250 sheets - Legal (216 x 356 mm)
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 50000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 25 pin D-Sub (DB-25)
- Power Device
- Power supply - internal
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32.5 °C
- 15 - 80%
- Sound Emission (Idle)
- 47 dBA
- Sound Emission (Operating)
- 68 dBA
- 37.8 cm
- 39 cm
- 25.5 cm
- 11.5 kg
