Your basket is empty
Epson AcuLaser CX29DNF A4 Colour Laser Multifunction Printer
Quicklinx: 8MJ2WS00 Mfr#: C11CB74021BW
Highly versatile: Consolidate printing, scanning, copying and faxing with a single device that has been designed to fit seamlessly into complex IT environments. Comes network-ready with numerous interfaces and emulations for easy integration, including Gigabit Ethernet, IPv6, Adobe PostScript 3 and PCL 5c/6.
High-quality results at speed: Increase the productivity of your business by printing and copying at high speeds of up to 23 pages per minute in both mono and colour, while ensuring your text and graphics documents are crisp and vibrant with a print resolution of up to 600 x 600dpi.
Tailor to your needs: Make your printer even more productive with an additional 250-sheet paper tray to increase capacity to 500 sheets. A high standard memory of 256MB can be increased by an additional 512MB to further boost performance.
Economical printing: The AcuLaser CX29DNF offers great value for money and its ENERGY STAR-qualified reduced power consumption helps businesses to further reduce total cost of ownership and environmental impact. Automatic double-sided printing as standard can help you save paper usage and costs by up to 50 percent.
Epson AcuLaser CX29DNF - multifunction printer (colour)
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 impressions
Max Copying Speed
Up to 16 ppm (mono) / up to 8 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 23 ppm (mono) / up to 23 ppm (colour)
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Media Type
Envelopes, plain paper, labels
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
AC 230 V (50/60Hz)
43 cm x 54.4 cm x 58.4 cm
29.8 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 impressions
Display
4 lines
Standard Memory
256 MB
Max Supported Memory
768 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PCL 5c
Automatic Duplexing
First Print Out Time B/W
15.5 sec
First Print Out Time Colour
15.5 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
9600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
8 station(s)
Speed Dialing
200 station(s)
Automatic redialing, group dialling
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
250 sheets
Max Media Capacity
500 sheets
150 sheets
Input tray - 250 sheets , Bypass tray - 1 sheet , ADF - 35 sheets
Speed Details
Copying: up to 16 ppm (A4) - B/W , Copying: up to 8 ppm (A4) - colour , Printing: up to 23 ppm (A4) - B/W , Printing: up to 23 ppm (A4) - colour , Scanning: up to 16 spm - B/W , Scanning: up to 8 spm - colour
1 x USB , 1 x USB host , 1 x Gigabit LAN
Network Protocols
TCP/IP, IPP, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, HTTPS, IPv4, IPv6, Bonjour, FTP, SMTP, DHCP, BOOTP, RARP
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.4.11 or later, MS Windows Server 2008, MS Windows Server 2008 R2
AC 230 V (50/60Hz)
410 Wh
Power Consumption Standby
60 Watt
Power Consumption Sleep
35 Watt
First Copy Out Time B/W
21 sec
First Copy Out Time Colour
30 sec
Consumables Included
1 x Cartridge (black) - up to 1000 pages , 1 x Cartridge (cyan) - up to 1000 pages , 1 x Cartridge (yellow) - up to 1000 pages , 1 x Cartridge (magenta) - up to 1000 pages
EN 61000-3-2, EN55022, EN 61000-3-3, EN 61000-4-4, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, EN 61000-4-8, EN 60950-1
ENERGY STAR Certified
Limited warranty - 1 year - on-site
43 cm
54.4 cm
58.4 cm
29.8 kg
Sound Emission
28 dBA (idle) / 53 dBA (operating)
10 °C
32 °C
15 - 80%
8MJ2 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.03
8MJ2 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.28
8MJ2 C2G 2-Port USB 2.0 Manual Switch In Stock £16.49
8MJ2 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.53
8MJ2 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
8MJ2 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.20
