Epson AcuLaser C9300D2TN A3 Colour Laser Printer
Quicklinx: 8MJRWS00 Mfr#: C11CB52011BQ
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
£2,042.38 ex VAT
£2,450.85 inc VAT
New technology - It offers Epson’s new Advanced Amplitude Modulation (AAM) screen technology to analyse dot placement and produce sharp images with well-defined edges.
High quality output - Epson's resolution improvement technology, AcuLaser Colour-RITech, eliminates uneven edges in text and delivers charts, graphics and even CAD schematics with clear, crisp tones.
Low TCO - It boasts Epson’s lowest cost-per-page for a laser in both mono and colour. This, in addition to its duplex capability which helps save up to 50% on paper usage, plus the ENERGY STAR-qualified reduced power consumption, mean that its TCO is very low.
Engineered for business - It has a compact footprint and the ability to print at up to A3 size in colour. Its print speed of up to 30ppm in A4 mono and colour helps boost productivity and a paper capacity of up to 2055 sheets saves on time refilling it. And the Gigabit Ethernet and PDL support with IPSec, IPv6 and SSL makes integration into complex IT environments hassle-free. It also offers automatic double-sided printing and two additional paper trays as standard.
High durability - It has a duty cycle of up to 100,000 pages, so businesses can be confident that their investment in the Epson range is a sound one.
  • Large capacity A3 colour
    This top-of-the-range A3 colour laser printer offers one of the highest print qualities in its class and a low TCO.
Epson AcuLaser C9300D2TN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
62.4 kg
Media Size Class
A3/Ledger
Max Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Min Media Size (Custom)
75 mm x 98 mm
Max Media Size (Custom)
297 mm x 431.8 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 21 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 21 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Image Enhancement Technology
4800RIT (Colour Resolution Improvement Technology)
Automatic Duplexing
USB, Gigabit LAN
400 MHz
RAM Installed (Max)
256 MB (1 GB) - DDR2 SDRAM
Language Simulation
PCL 5C, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P, PDF 1.6
Media Type
Envelopes, plain paper
Total Media Capacity
1505 sheets
Media Handling
250-sheet input tray, 2x 550-sheet input trays, 155-sheet multipurpose tray
Monthly Duty Cycle (max)
100000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - internal
AC 230V
Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
1-year warranty
50 cm x 53.8 cm x 69.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, Gigabit LAN
1200 dpi
Automatic Duplexing
First Print Out Time B/W
8.3 sec
First Print Out Time Colour
9.9 sec
Language Simulation
Media Handling
400 MHz
RAM
RAM Installed (Max)
256 MB / 1 GB (max)
Technology / Form Factor
DDR2 SDRAM
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
75 mm x 98 mm
297 mm x 431.8 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), F4
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm)
Max Printing Width
293 mm
Max Printing Length
425.8 mm
Media Weight
60 g/m² - 216 g/m²
1505 sheets
Media Feeders
1 x automatic - 155 sheets , 1 x automatic - 250 sheets , 2 x automatic - 550 sheets
Max Media Capacity
2055 sheets
Output Trays Capacity
150 sheets
Duty Cycle
100000 pages
Print server - internal
Network / Transport Protocol
TCP/IP, AppleTalk, LPR/LPD, FTP, BOOTP, DHCP, DDNS
Remote Management Protocol
SNMP, IPP, HTTP
Security Protocols & Features
IPsec
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
458 Watt
Power Consumption Stand by / Sleep
56 Watt
Software Included
Drivers & Utilities, EPSON Web-to-Page, EpsonNet Print, EpsonNet Config, EPSON Status Monitor
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
5 °C
32 °C
15 - 85%
Sound Emission (Idle)
25 dBA
Sound Emission (Operating)
53 dBA
50 cm
53.8 cm
69.8 cm
62.4 kg
Ink (4)
8MJR Epson AL-C9300N Double Pack Toner Cartridge Yellow 7.5k x2 In Stock £280.57
8MJR Epson AL-C9300N Double Pack Toner Cartridge Magenta 7.5k x2 In Stock £280.57
8MJR Epson AL-C9300N Double Pack Toner Cartridge Cyan 7.5k x2 In Stock £280.57
8MJR Epson AL-C9300N Double Pack Toner Cartridge Black 6.5k x2 In Stock £140.36
Other bundles (4)
8MJR C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
8MJR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
8MJR C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.07
8MJR C2G 2m Cat6a Shielded Patch - Blue In Stock £7.44
Type: Printer
Output Type: Colour
Technology: Laser
Max Print Speed: 30ppm
Max Paper Size: A3 (297 x 420 mm)
Max Paper Size: ANSI B (Ledger) (279 x 432 mm)
Brand: Epson
Price Range Ex VAT: 1500+
