Epson 4000 ANSI Lumens WUXGA 3LCD Technology Installation Projecto
Quicklinx: D9LGWS00 Mfr#: V11H877041
Portability: Non-portable
26 in stock
£1,755.56 ex VAT
£2,106.67 inc VAT
Bring the classroom to life with a scalable image up to 100 inches
Ensure students can read everything on the screen with this large scalable laser display, combining Full HD WUXGA resolution and 4,000 lumens of brightness. Epson's 3LCD technology delivers equally-high white and colour light output (CLO).
Hassle-free lessons
Ease of connectivity and simple set-up enables lessons to get underway without delay. Auto Power On starts up the device when a cable connection is detected. HDMI connectivity also means that students benefit from clearer, sharper content, and a 16W integrated speaker and microphone input remove the need for additional audio installation.
Collaborate seamlessly
Wireless connectivity via an optional USB dongle makes it easy to connect a range of mobile devices using Epson's iProjection app . Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what student content to display, including collaboration with laptops and mobile devices using whiteboard annotation. Dual-pen and finger-touch allow teachers and students to annotate directly onto the screen.
Split screen
Display content from two sources simultaneously, such as a lesson plan and live feed from a document camera, without needing two separate display devices.
  • Laser classroom solution
    Maintenance-free interactive display solution making use of a large, scalable screen up to 100 inches to enhance learning without disruption.
  • Bring the classroom to life with large, scalable images
    Enjoy a larger display size of up to 100 inches in classrooms and other teaching spaces with this 4,000 lumens WUXGA product. It benefits from Epson's equally high white and colour light output (CLO) to deliver bright and vivid images. And with a 2,500,000:1 dynamic contrast ratio blacks are dark and images crisp and clear.
  • Hassle-free lessons
    Ease of connectivity and simple set-up means lessons get underway without delay. Auto Power On starts up the device when a cable connection is detected. HDMI connectivity also means that students benefit from clearer, sharper content, and a 16W integrated speaker and microphone input remove the need for additional audio installation.
  • Collaborate seamlessly
    Make collaboration simple, with digital annotation, finger-touch control, and the ability for staff and pupils to present from their own devices-Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what student content to display. Wireless connectivity via an optional USB dongle (ELPAP10) makes it easy to connect a range of mobile devices using Epson's-Collaborate with laptops and mobile devices using whiteboard annotation-Display content from two sources simultaneously, with split-screen, such as a lesson plan and live feed from a document camera, without needing two separate display devices.-Dual-pen and finger-touch annotation for easy control.
Epson EB-710Ui - 3LCD projector - ultra short-throw - LAN
3LCD projector - 1080p
Grey, white
Built-in Devices
Speaker
Brightness (White)
4000 lumens
Brightness (Colour)
4000 lumens
Contrast Ratio
2500000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Ultra short-throw lens
Bulb type
Laser diode
Bulb life cycle
Up to 12000 hour(s) - normal mode , Up to 20000 hour(s) - economic mode
Video Input
RGB, S-Video LAN
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified Projectors 2
AC 120/230 V (50 - 60 Hz)
423 Watt
49.4 cm x 43.7 cm x 17.5 cm
11.2 kg
5-year warranty
Built-in Devices
Speaker
Ethernet
Enclosure Colour
Grey, white
Projector
Brightness (White)
4000 lumens
Brightness (Colour)
4000 lumens
Brightness (Reduced)
2800 lumens
Contrast Ratio
2500000:1 (dynamic)
Image Size
178 cm - 254 cm
Projection Distance
0.4 m - 0.6 m
Throw Ratio
0.27 - 0.37:1
Digital Zoom Factor
1.35x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
240 Hz
Bulb type
Laser diode
Bulb life cycle
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Automatic Brightness Adjustment, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
RGB, S-Video
Video Interfaces
VGA, HDMI, S-Video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out
Wall mounting kit, pen tray, wireless remote control, finger touch unit, interactive pens
1 x USB cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, Wireless LAN Lock
TCO Certified
Power Source
AC
Nominal Voltage
423 Watt
Power Consumption Stand by
0.5 Watt
Software Included
Epson Easy Interactive Tools, EasyMP Multi PC Projection
49.4 cm
43.7 cm
17.5 cm
11.2 kg
Limited warranty - 5 years / 12000 hours - carry-in
5 °C
20 - 80%
Sound Emission
39 dBA
30 dBA
Brand: Epson
Price Range Ex VAT: 1500+
