Bring the classroom to life with a scalable image up to 100 inches
Ensure students can read everything on the screen with this large scalable laser display, combining Full HD WUXGA resolution and 4,000 lumens of brightness. Epson's 3LCD technology delivers equally-high white and colour light output (CLO).
Hassle-free lessons
Ease of connectivity and simple set-up enables lessons to get underway without delay. Auto Power On starts up the device when a cable connection is detected. HDMI connectivity also means that students benefit from clearer, sharper content, and a 16W integrated speaker and microphone input remove the need for additional audio installation.
Collaborate seamlessly
Wireless connectivity via an optional USB dongle makes it easy to connect a range of mobile devices using Epson's iProjection app . Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what student content to display, including collaboration with laptops and mobile devices using whiteboard annotation. Dual-pen and finger-touch allow teachers and students to annotate directly onto the screen.
Split screen
Display content from two sources simultaneously, such as a lesson plan and live feed from a document camera, without needing two separate display devices.
Laser classroom solution
Maintenance-free interactive display solution making use of a large, scalable screen up to 100 inches to enhance learning without disruption. -
Bring the classroom to life with large, scalable images
Enjoy a larger display size of up to 100 inches in classrooms and other teaching spaces with this 4,000 lumens WUXGA product. It benefits from Epson's equally high white and colour light output (CLO) to deliver bright and vivid images. And with a 2,500,000:1 dynamic contrast ratio blacks are dark and images crisp and clear. -
Hassle-free lessons
Ease of connectivity and simple set-up means lessons get underway without delay. Auto Power On starts up the device when a cable connection is detected. HDMI connectivity also means that students benefit from clearer, sharper content, and a 16W integrated speaker and microphone input remove the need for additional audio installation. -
Make collaboration simple, with digital annotation, finger-touch control, and the ability for staff and pupils to present from their own devices-Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what student content to display. Wireless connectivity via an optional USB dongle (ELPAP10) makes it easy to connect a range of mobile devices using Epson's-Collaborate with laptops and mobile devices using whiteboard annotation-Display content from two sources simultaneously, with split-screen, such as a lesson plan and live feed from a document camera, without needing two separate display devices.-Dual-pen and finger-touch annotation for easy control.
- Epson EB-710Ui - 3LCD projector - ultra short-throw - LAN - grey, white
- 3LCD projector - 1080p
- Grey, white
- Built-in Devices
- Speaker
- Brightness (White)
- 4000 lumens
- Brightness (Colour)
- 4000 lumens
- Contrast Ratio
- 2500000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Lens
- Ultra short-throw lens
- Bulb type
- Laser diode
- Bulb life cycle
- Up to 12000 hour(s) - normal mode , Up to 20000 hour(s) - economic mode
- Video Input
- RGB, S-Video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 423 Watt
- 49.4 cm x 43.7 cm x 17.5 cm
- 11.2 kg
- 5-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- Grey, white
Projector
- 4000 lumens
- 4000 lumens
- Brightness (Reduced)
- 2800 lumens
- Contrast Ratio
- Image Size
- 178 cm - 254 cm
- Projection Distance
- 0.4 m - 0.6 m
- Throw Ratio
- 0.27 - 0.37:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 240 Hz
- Bulb type
- Laser diode
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Automatic Brightness Adjustment, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- RGB, S-Video
- Video Interfaces
- VGA, HDMI, S-Video, MHL
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out
- Included Accessories
- Wall mounting kit, pen tray, wireless remote control, finger touch unit, interactive pens
- Cables Included
- 1 x USB cable
- Mounting Kit
- Included
- Security Features
- Security lock slot (cable lock sold separately), password protection, control panel lock, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 423 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- Epson Easy Interactive Tools, EasyMP Multi PC Projection
- 49.4 cm
- 43.7 cm
- 17.5 cm
- 11.2 kg
- Limited warranty - 5 years / 12000 hours - carry-in
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 39 dBA
- Sound Emission (Economic Mode)
- 30 dBA
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £96.86 |
Epson Wireless Adaptor LAN B/G/N | In Stock | £101.99 |
Epson ELPDC07 Digital Document Camera | In Stock | £180.47 |
