Any meeting room can benefit from interactivity with the ultra-short-throw projector, featuring dual pen capability, a high brightness level of 3,800 lumens, Full HD WUXGA resolution and remote multi-location connectivity. The ultrashort-throw EB-1440Ui is designed to present a scalable screen size of up to 100 inches to deliver the requirements of any business working environment.
Up to 100-inch display and outstanding quality
Full HD WUXGA resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity also means that the audience benefits from sharper and clearer content displayed in any meeting room environment. -
All-in-one office solution
This interactive meeting room solution combines the benefits of flipcharts, whiteboards and conventional screens into one unified meeting room solution. Meeting participants can view and annotate whiteboard content from a range of smart devices, without the need for any special application, ensuring information remains secure with the ability to apply passwords to meetings and notes. The remote desktop feature promotes freedom from the desktop – simply leave your PC, including those running Windows 10, on your desk and present from anywhere around the office. Take advantage of Skype in business and other video call solutions during meetings. -
Dual pen
Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, colleagues can work simultaneously using different pen attributes. -
Sliding split screen
Combine two sources and project, such as multi-source video conference and presentation, to optimise interaction. -
Wireless connectivity
Share content easily from a range of smart devices using the iProjection App.
- Epson EB-1440Ui - 3LCD projector - 802.11n wireless / LAN - white
- 3LCD projector - 1080p
- White
- Built-in Devices
- Speaker
- Brightness (White)
- 3800 lumens
- Brightness (Colour)
- 3800 lumens
- Contrast Ratio
- 300:1 / 16000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 267 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video IEEE 802.11n wireless / LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 401 Watt
- 47.4 cm x 44.7 cm x 13 cm
- 8.4 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Networking
- 802.11b/g/n, Ethernet
- Enclosure Colour
- White
Projector
- 3800 lumens
- 3800 lumens
- Brightness (Reduced)
- 2900 lumens
- Contrast Ratio
- Image Size
- 178 cm - 254 cm
- Projection Distance
- 0.4 m - 0.6 m
- Throw Ratio
- 0.27 - 0.37:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Bulb type
- 267 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Direct Power On, Direct Power Off, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode, Auto Calibration
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D output - 24+1 pin digital DVI , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out , 1 x serial RS-232C , 1 x composite video input - RCA
- Included Accessories
- Wall mounting kit, wireless remote control, wireless LAN unit, pen case, interactive pens, pen tips
- Cables Included
- 1 x USB cable
- Mounting Kit
- Included
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Power Source
- AC
- Voltage Required
- 401 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- Epson Easy Interactive Tools, EasyMP Monitor, EasyMP Multi PC Projection
- 47.4 cm
- 44.7 cm
- 13 cm
- 8.4 kg
- Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 30 dBA
