Epson 3800 ANSI Lumens WUXGA 3LCD UST Interactive Projector
Quicklinx: CMT0WS00 Mfr#: V11H771041
Any meeting room can benefit from interactivity with the ultra-short-throw projector, featuring dual pen capability, a high brightness level of 3,800 lumens, Full HD WUXGA resolution and remote multi-location connectivity. The ultrashort-throw EB-1440Ui is designed to present a scalable screen size of up to 100 inches to deliver the requirements of any business working environment.
  • Up to 100-inch display & outstanding quality
    Full HD WUXGA resolution with Epson's 3LCD technology.
  • All-in-one office solution
    Various office equipment in one interactive collaboration device.
  • Increase integration and collaboration
    Share content from a range of devices simultaneously.
  • Dual pen annotation
    Now even more responsive and easy to use.
  • Whiteboard sharing mode
    Invite and share meetings notes with participants.
Epson EB-1440Ui - 3LCD projector - 802.11n wireless / LAN
3LCD projector - 1080p
White
Built-in Devices
Speaker
Brightness (White)
3800 lumens
Brightness (Colour)
3800 lumens
Contrast Ratio
300:1 / 16000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
267 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video IEEE 802.11n wireless / LAN
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified Projectors 2
AC 230V (50 - 60 Hz)
401 Watt
47.4 cm x 44.7 cm x 13 cm
8.4 kg
3-year warranty
Built-in Devices
Speaker
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
3800 lumens
Brightness (Colour)
3800 lumens
Brightness (Reduced)
2900 lumens
Contrast Ratio
Image Size
178 cm - 254 cm
Projection Distance
0.4 m - 0.6 m
Throw Ratio
0.27 - 0.37:1
Digital Zoom Factor
1.35x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Bulb type
267 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Direct Power On, Direct Power Off, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode, Auto Calibration
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D output - 24+1 pin digital DVI , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out , 1 x serial RS-232C , 1 x composite video input - RCA
Wall mounting kit, wireless remote control, wireless LAN unit, pen case, interactive pens, pen tips
1 x USB cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection
TCO Certified
Power Source
AC
Nominal Voltage
401 Watt
Power Consumption Stand by
0.5 Watt
Software Included
Epson Easy Interactive Tools, EasyMP Monitor, EasyMP Multi PC Projection
47.4 cm
44.7 cm
13 cm
8.4 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
30 dBA
