Bright, vivid content on a large scalable screen
View content like never before and pick out even the finest detail with crisp, clear images with a screen size up to 320 inches. The combination of a high brightness, high contrast ratio of 15,000:1, and HD Ready content provides superior image quality and a viewing experience that is easy on the eye, even in high ambient lighting conditions.
Years of uninterrupted meetings
With a lamp life and air filter maintence cycle of 10,000 hours in eco mode, users won't need to worry about maintenance for up to 5 years .
Installation and placement flexibility
Automatic vertical and manual horizontal keystone correction provide greater flexibility as to where the projector can be placed in the room for distortion-free images and the wide optical zoom adds to the flexibility.
Flexible connectivity for greater sharing
Built-in Wi-Fi enables easy and intuitive access to the projector from compatible smart devices using the iProjection app . Display content with the freedom to move around and engage with your audience. Split screen capability allows content from more than one device to be displayed simultaneously without the need for two separate display devices.
Compact display solution
This WXGA-resolution device can be positioned almost anywhere to deliver years of uninterrupted presentations on a large scalable screen.
- Epson EB-W42 - 3LCD projector - portable - 802.11n wireless - black, white
- 3LCD projector - 720p
- Black, white
- Built-in Devices
- Speaker
- Brightness (White)
- 3600 lumens
- Brightness (Colour)
- 3600 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video IEEE 802.11n wireless
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 282 Watt
- 30.2 cm x 23.7 cm x 8.2 cm
- 2.5 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Networking
- 802.11b/g/n
- Enclosure Colour
- Black, white
Projector
- 3600 lumens
- 3600 lumens
- Brightness (Reduced)
- 2235 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 84 cm - 813 cm
- Throw Ratio
- 1.3 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.49-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) , 1 x audio line-in - RCA x 2
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable , 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 282 Watt
- Power Consumption Stand by
- 0.2 Watt
- Software Included
- EasyMP Network Projection, EasyMP Multi PC Projection
- 30.2 cm
- 23.7 cm
- 8.2 cm
- 2.5 kg
- Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £101.71 |
