Epson 3600 ANSI Lumens WXGA 3LCD Technology Meeting Room Projector
Quicklinx: D7G6WS00 Mfr#: V11H845041
Portability: Portable
16 in stock
£491.89 ex VAT
£590.26 inc VAT
Bright, vivid content on a large scalable screen
View content like never before and pick out even the finest detail with crisp, clear images with a screen size up to 320 inches. The combination of a high brightness, high contrast ratio of 15,000:1, and HD Ready content provides superior image quality and a viewing experience that is easy on the eye, even in high ambient lighting conditions.
Years of uninterrupted meetings
With a lamp life and air filter maintence cycle of 10,000 hours in eco mode, users won't need to worry about maintenance for up to 5 years .
Installation and placement flexibility
Automatic vertical and manual horizontal keystone correction provide greater flexibility as to where the projector can be placed in the room for distortion-free images and the wide optical zoom adds to the flexibility.
Flexible connectivity for greater sharing
Built-in Wi-Fi enables easy and intuitive access to the projector from compatible smart devices using the iProjection app . Display content with the freedom to move around and engage with your audience. Split screen capability allows content from more than one device to be displayed simultaneously without the need for two separate display devices.
  • Compact display solution
    This WXGA-resolution device can be positioned almost anywhere to deliver years of uninterrupted presentations on a large scalable screen.
Epson EB-W42 - 3LCD projector - portable - 802.11n wireless
3LCD projector - 720p
Black, white
Built-in Devices
Speaker
Brightness (White)
3600 lumens
Brightness (Colour)
3600 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
UHE 210 Watt
Bulb life cycle
Up to 6000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video IEEE 802.11n wireless
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified Projectors 2
282 Watt
30.2 cm x 23.7 cm x 8.2 cm
2.5 kg
3-year warranty
Built-in Devices
Speaker
802.11b/g/n
Enclosure Colour
Black, white
Projector
Brightness (White)
3600 lumens
Brightness (Colour)
3600 lumens
Brightness (Reduced)
2235 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
84 cm - 813 cm
Throw Ratio
1.3 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
UHE 210 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.49-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) , 1 x audio line-in - RCA x 2
Carrying case, wireless remote control
1 x VGA cable , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
TCO Certified
Power Source
AC
Nominal Voltage
282 Watt
Power Consumption Stand by
0.2 Watt
Software Included
EasyMP Network Projection, EasyMP Multi PC Projection
30.2 cm
23.7 cm
8.2 cm
2.5 kg
Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
Brand: Epson
Price Range Ex VAT: 300 - 500
