DURABrite Ultra ink helps you print brilliant reports, charts and photos. With exceptional results on both plain and photo paper, it's the most versatile ink around. DURABrite Ultra ink is an outstanding pigment-based ink technology that not only gives you the superior image quality you need, but provides the water, smudge, and light resistance you want. If you're looking for ink that delivers exceptional quality and durability, the solution is clear - DURABrite Ultra ink.
Prints that last on any paper
DURABrite Ultra ink lasts and lasts. For your important documents, DURABrite ink resists fading up to six times longer than the leading competitor on plain paper. Plus prints on photo paper resist fading up to 100 years, so each print is sure to be cherished for years to come. -
Durable prints
Quick-drying formula allows documents and photos to be handled immediately after printing with no smudging. Photos resist damage related to high levels of humidity, moisture and water spills on Epson photo papers.
- Epson T7022 - XL size - cyan - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Cyan
- Cartridge Yield
- XL size
- Cartridge Features
- Epson DURABrite Ultra
- Yield
- Up to 2000 pages
- Packaging Type
- Blister
- Compatible with
- WorkForce Pro WP-4015 DN, WP-4025 DW, WP-4095 DN, WP-4515 DN, WP-4525 DNF, WP-4535 DWF, WP-4545 DTWF, WP-4595 DNF
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Cyan
- Included Qty
- 1-pack
- Cartridge Yield
- XL size
- Yield
- Up to 2000 pages
- Packaging Type
- Blister
- Compatible with
- Epson WorkForce Pro WP-4015 DN, WP-4025 DW, WP-4095 DN, WP-4515 DN, WP-4525 DNF, WP-4535 DWF, WP-4545 DTWF, WP-4595 DNF
