The XP4006 rechargeable battery is the perfect portable charger for smart phones and tablet with USB input port! The dual USB output design can charge two devices at once, XP4006 got all the support you need for your power hungry gadgees.
Powerful
4000 mAh battery for extra power
LED Light Indicator
Smart LEDs show battery and charging status.
Portable
Conveniently small and lightweight.
Rechargeable
Up to 500 times
Specs
Battery Type - Lithium Polymer
Battery Capacity - 4000 mAh
Input Specification - 5V, 1A
Output Specification - DC 5V, 1A / DC 5V,2.1A
Weight - 109g
Dimensions - 7.4(L) x 5.8(W) x 2.1(H) cm
- Energizer Energi To Go XP4006 power bank - Li-pol - USB
- Product Type
- Power bank
- 5.8 cm x 7.4 cm x 2.1 cm
- 109 g
- Black
- Output Connector Type
- Total 2: USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 2.1 A
- Battery
- Lithium polymer - 4000 mAh
- Power Device Details
- - 4 pin USB Type A - 5 V - 2 A , - 4 pin USB Type A - 5 V - 1 A
- Cables
- Micro-USB to USB cable
- 3-year warranty
- Product Type
- Power bank
- Designed For
- Portable player, tablet, mobile phone
- 5.8 cm
- 7.4 cm
- 2.1 cm
- 109 g
- Enclosure Colour
- Black
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2.1 A
- 4 pin USB Type A - 5 V - 2 A , 4 pin USB Type A - 5 V - 1 A
- Over voltage protection
- Technology
- Lithium polymer
- Capacity
- 4000 mAh
- Recharge Time
- 4 hours
- LED power meter, overheat protection, overcurrent protection, auto shut-off, Powersafe technology
- Cables Included
- Limited warranty - 3 years
