Energizer® UE2601 is a small cylinder shaped viewing stand and battery charger with a small, extendable rubber slip mat for propping up smarthphones and other media devices while charging.
Portability
Small and light weight, the cylinder shaped design easily fits in a pocket, purse, or bag, making it extremely portable for on-the-go charging.
Viewing Stand
Built-in, extendable rubber slip mat creates an all-in-one viewing stand and charger by securely propping up your smartphone while you charge.
Powerful
2,600 mAh of power provides a strong boost of power for watching movies, viewing presentations, sharing pictures, and much more.
Style
Hard plastic housing provides sturdy protection against drops and falls while a glossy finish and metallic end caps display the modern sophistication associated with the Energizer® brand.
Safety Technologies
Backed by the Energizer brand, UE2601 comes standard with state-of-the-art, XPAL Inside™ safety technologies for a trusted charge that won’t damage your device
Specs
Battery Type - Lithium-ion
Battery Capacity - 2600 mAh
Input Specification - DC 5V, 1A
Output Specification - DC 5V, 1A
Weight - 68g
Dimensions - 96.2(L) x 26(W) x 26(H)mm
Portability
Small and light weight, the cylinder shaped design easily fits in a pocket, purse, or bag, making it extremely portable for on-the-go charging. -
Viewing stand
Built-in, extendable rubber slip mat creates an all-in-one viewing stand and charger by securely propping up your smartphone while you charge. -
Powerful
2,600 mAh of power provides a strong boost of power for watching movies, viewing presentations, sharing pictures, and much more. -
Style
Hard plastic housing provides sturdy protection against drops and falls while a glossy finish and metallic end caps display the modern sophistication associated with the Energizer brand. -
Safety technologies
Backed by the Energizer brand, UE2601 comes standard with state-of-the-art, XPAL Inside safety technologies for a trusted charge that won't damage your device.
- Energizer UE2601 power bank - Li-Ion - USB
- Product Type
- Power bank
- 2.6 cm x 9.62 cm x 2.6 cm
- 68 g
- Black
- Output Connector Type
- USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 1 A
- Battery
- Lithium Ion - 2600 mAh
- Cables
- Micro-USB to USB cable
- Product Type
- Power bank
- Designed For
- Mobile phone
- 2.6 cm
- 9.62 cm
- 2.6 cm
- 68 g
- Enclosure Colour
- Black
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 1 A
- Phone stand
- Technology
- Lithium Ion
- Capacity
- 2600 mAh
- Cables Included
