Product
Energenie Mi Home Style -  Double Socket - Nickel
Quicklinx: CZGFWS00 Mfr#: MIHO021
The MiHome Double Wall Socket is a radio controlled unit with individual power switching for each socket. Switching is initiated either by radio control signal or manually by pressing the button on the housing.
Energenie Mi|Home Double Wall Socket - socket switch
Socket switch
Functions
Turn power on/off
Wireless
Frequency Band
433.92 MHz
Nickel
United Kingdom
14.5 cm x 3.3 cm x 8.5 cm
Socket switch
Functions
Turn power on/off
Wireless
Max Range Indoors
25 m
Frequency Band
433.92 MHz
Indoor usage, in-wall mountable, on / off button, LED indicator, up to 3000 Watt (each socket) OOK modulation
Nickel
United Kingdom
Nominal Voltage
AC 230V
BS 5733, IP20, DIN EN 61058-1, EN 301 489-1, EN 62479, RTTE
14.5 cm
3.3 cm
8.5 cm
210 g
-5 °C
