Product
Brand
Energenie Mi Home Radiator Valve 4 pack
Quicklinx: CZGCWS00 Mfr#: MIHO013-4
Type: Radiator thermostat
Compatible With: Alexa, Nest
£162.49 ex VAT
£194.98 inc VAT
This Mi Home Radiator Valve 4 pack requires the Mi|Home Gateway to work, available seperately. Search QL CZFF and see bundles to buy together
Make your home smarter with Mi Home Radiator Valves
  • Take control of your heating, lighting and electrical devices wherever you are
  • FREE iOS and Android App, plus browser interface
  • Easy to fit to existing TRV body - just unscrew your existing TRV head - no plumber required
  • 1 Year battery life, dual thermostat, ultra quiet motor
  • Communicates current and target temperatures to the Mi|Home Gateway, as well as battery status
Mi|Home Smart Radiator Valves provide automatic control and zoning of your heating system. Each valve can be programmed by time and temperature, so you only heat the rooms you want to the temperature you specify. Use Geofencing and IFTTT to fully automate your heating. A true whole-of house Smart Home
Box Contains
  • 4 x Mi|Home Smart Radiator Valves
  • 8 X AA batteries
  • 4 spacer rings
  • 8 adapter collars
  • Instructions
Energenie Mi|Home Radiator Valve - radiator thermostat
Radiator thermostat
Packaged Quantity
4 (specifications are for single item)
Functions
Control heating systems
Power Source
Internet of Things (IoT) Platform
OpenThings
Wireless
Frequency Band
434.3 MHz
4.5 cm x 4.5 cm x 11 cm
Packaged Quantity
Radiator thermostat
Functions
Power Source
Wireless
Max Range Open Space
25 m
Frequency Band
434.3 MHz
IFTTT compatible, built-in temperature sensor, LED indicator
Platform
OpenThings
Communications Type
Product-to-product
Battery Required
2 x AA type - Alkaline
R&TTE, IP20
4.5 cm
4.5 cm
11 cm
5 °C
Compatible With: Nest
Brand: Energenie
Price Range Ex VAT: 150 - 300
