Product
Energenie Mi Home In Line Controller
Quicklinx: CZGDWS00 Mfr#: MIHO014
The MIHO014 In- Line Relay is a radio controlled switch for the switching of mains power to lighting and appliances. Switching is initiated either by radio control signal or manually by pressing the button on the housing.
Energenie Mi|Home In- Line Relay - relay switch
Relay switch
Functions
Turn power on/off
Wireless
Frequency Band
433 MHz
White
6.4 cm x 3.8 cm x 6.5 cm
Relay switch
Functions
Turn power on/off
Wireless
Max Range Indoors
25 m
Frequency Band
433 MHz
Indoor usage, up to 3000 Watt, in-wall mountable, on / off button, LED indicator OOK modulation
Product Material
Plastic
White
Nominal Voltage
AC 230V
R&TTE, IP20, EN 301 489-1, EN 60669-2-1
6.4 cm
3.8 cm
6.5 cm
70 g
-5 °C
