Energenie Mi Home Heating Starter Pack
Quicklinx: CZH2WS00 Mfr#: MIHO029
This is the Mi, Home heating bundle, consisting of radiator valves and gateway. Each eTRV controls a radiator valve to regulate the heating in the room, based on timed programs, set temperatures. Using the eTRV improves your comfort and saves energy. The benefit of having eTRVs is that it enables you to control each radiator or room individually, rather than heating your whole house from a single thermostat. Therefore you only heat the bedroom, when it is in use, which is likely to be at a different time to the lounge or sitting room. By only heating the rooms you are in you can make significant savings. The radiator valves can be used with other features, such as programs. This means, you are able to set the required radiator valve to a specific temperature and at specific time on your settings in the app.
Energenie Mi|Home Heating Pack - home automation kit
Home automation kit
Functions
Control heating systems
Internet of Things (IoT) Platform
Hue, OpenThings
Package Content
Gateway, radiator thermostat
Wireless
Frequency Band
434.3 MHz
Home automation kit
Functions
Package Content
Components
3 x radiator thermostat , Gateway
Wireless
Max Range Open Space
25 m
Frequency Band
434.3 MHz
LED indicator
Platform
Hue, OpenThings
Communications Type
Product-to-product
Compatible Services
IFTTT
IP20
Dimensions & Weight Details
Radiator thermostat: 4.5 cm x 4.5 cm x 11 cm
