This pack of 3 plug-in adapters require the Mi, Home Gateway to work, available seperately. Search QL CZFF and see bundles to buy together
Make your home smarter with Mi, Home! Alexa Controlled Smart Plugs
The Mi, Home adapters can be controlled via the Mi, Home app or web browser using the Mi, Home Gateway. This product receives commands from the Mi, Home gateway and doesn't send a confirmation of action back to it. The adapters can also be used with our other features such as timers. As well as timers, the Sockets can be controlled with IFTTT (If This Then That), this allows you to turn them on using the weather, ESPN, facebook to name but a few. It also means they can be used in conjunction with the Phillips Hue and Nest, for example.
Take control of your electrical devices wherever you are
- FREE iOS and Android App, plus browser interface
- 3-pack of plug-in control adapters
- Switch on/off via the Mi, Home App or set timers, use geofencing or IFTTT to control automatically
- 13Amp 3120 Watt rated
- Mi, Home adapters can be controlled via the Mi, Home app or web browser using our Mi, Home Gateway
- Energenie Mi|Home Adapter - smart plug (pack of 3)
- Product Type
- Smart plug
- Packaged Quantity
- 3 (specifications are for single item)
- Internet of Things (IoT) Platform
- Hue
- Connectivity
- Wireless
- Frequency Band
- 433.92 MHz
- Localisation
- United Kingdom
- 1-year warranty
- 12 cm x 6.5 cm x 18 cm
- Packaged Quantity
- Product Type
- Smart plug
- Connectivity Technology
- Wireless
- Max Range Indoors
- 25 m
- Frequency Band
- 433.92 MHz
- Up to 3000 Watt, timer
- Platform
- Hue
- Compatible Services
- IFTTT
- Localisation
- United Kingdom
- Nominal Voltage
- AC 230V
- Warranty
- 1-year warranty
- 0.3 Watt
- 12 cm
- 6.5 cm
- 18 cm
- 338 g
