Your basket is empty
Emulex OneConnect™ Dual-Port 10Gb/s Eth. Network & iSCSI Adapter
Quicklinx: 7VFCWS00 Mfr#: OCe11102-IX
Emulex OneConnect OCe11102-IX dual-port 10Gb/s iSCSI adapters with copper interconnects provide optimized performance for iSCSI storage and Ethernet networking. Based on the third-generation BE3 controller, the OCe11102-IX reduces power costs with leading scalability per watt and supports full iSCSI and TCP/IP protocol offloads.
Emulex OneConnect OCE11102-IX - network adapter - 2 ports
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
Ports Qty
2 ports
Cabling Type
Ethernet 10GBase-CR
10 GigE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3ak
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux Server
Microsoft Certification
Compatible with Windows 7
Network adapter - 2 ports
Plug-in card
PCI Express 2.0 x8
PCIe 2.0
Wired
Cabling Type
Ethernet 10GBase-CR
10 GigE
Data Transfer Rate
10 Gbps
Flow control, VLAN support, IPv6 support, Accelerated iSCSI, Quality of Service (QoS), IPv4 support, PXE support, Large Send Offload (LSO), Receive Side Scaling (RSS)
2 x 10GBase-CR
Compatible Slots
1 x PCI Express 2.0 x8
C-Tick, CISPR 22 Class A, VCCI Class A ITE, EN55024, EN55022 Class A, EMC, ICES-003 Class A, RoHS, EN 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1-07, FCC Part 15 A, EN 60825-1, BSMI Class A, KCC Class A
55 °C
5 - 95% (non-condensing)
