Emulex OneConnect OCe11102-IX dual-port 10Gb/s iSCSI adapters with copper interconnects provide optimized performance for iSCSI storage and Ethernet networking. Based on the third-generation BE3 controller, the OCe11102-IX reduces power costs with leading scalability per watt and supports full iSCSI and TCP/IP protocol offloads.
10 Gigabit Ethernet offload
Multi-core server platforms, server virtualization and high-demand applications, such as video on demand and voice over Internet protocol (VOIP) are all driving the need for low latency and high bandwidth. The OCe11102-I iSCSI adapter delivers optimized 10GbE performance that meets these requirements with support for TCP/IP and TCP chimney offloads. -
iSCSI offload
The OCe11102-I iSCSI adapter supports iSCSI offload, providing performance that is superior to iSCSI solutions based on software initiators and standard Network Interface Cards (NICs). -
Boot from LAN/SAN
Preboot eXecution Environment (PXE) and iSCSI boot support make the OCe11102-I an ideal solution for blade servers and other diskless deployments. -
OneCommand Manager
OneCommand Manager provides centralized management of Emulex One Connect UCNAs and HBAs throughout the data center from a centralized management console. OneCommand Manager provides a graphical user interface (GUI) and a scriptable command line user interface (CLI), which drive administration efficiency and business agility. Centralized discovery, monitoring and management of local and remote adapters can be done from a secure remote client. In-depth management capabilities include firmware and boot code upgrades, beaconing, statistics and advanced diagnostics. -
More virtual machines per server with vEngine technology
Protocol offloads for TCP/IP and iSCSI enable more VMs per server, providing greater cost savings for server virtualization. -
Green data centers
The OCe11102-I uses the BladeEngine 3 controller with integrated Network Controller Sideband Interface (NC-SI) and KR (Backplane Ethernet) Serializer/ Deserializer (SerDes) interfaces to minimize power usage. Protocol offload enables efficient use of computing resources, supports more VMs per CPU and reduces the number of servers required to support data center demands. -
Advanced error checking
End-to-end data protection with hardware parity, CRC, ECC and other advanced error checking and correcting ensure that data is safe from corruption.
- Emulex OneConnect OCE11102-IX - network adapter - PCIe 2.0 x8 - 2 ports
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x8
- PCI Specification Revision
- PCIe 2.0
- Ports Qty
- 2 ports
- Cabling Type
- Ethernet 10GBase-CR
- Data Link Protocol
- 10 GigE
- Data Transfer Rate
- 10 Gbps
- TCP/IP, UDP/IP, iSCSI
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3ak
- System Requirements
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux Server
- Microsoft Certification
- Compatible with Windows 7
- Network adapter - 2 ports
- Form Factor
- Plug-in card
- PCIe 2.0
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 10 Gbps
- Flow control, VLAN support, IPv6 support, Accelerated iSCSI, Quality of Service (QoS), IPv4 support, PXE support, Large Send Offload (LSO), Receive Side Scaling (RSS)
- 2 x 10GBase-CR
- Compatible Slots
- 1 x PCI Express 2.0 x8
- C-Tick, CISPR 22 Class A, VCCI Class A ITE, EN55024, EN55022 Class A, EMC, ICES-003 Class A, RoHS, EN 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1-07, FCC Part 15 A, EN 60825-1, BSMI Class A, KCC Class A
- OS Required
- 0 °C
- 55 °C
- 5 - 95% (non-condensing)
