Extra juice right when you need it! The Power Clip is a back-up battery for your smartphone when it runs out of power.
- EMTEC Power Clip U400 power bank - Li-Ion - Micro-USB Type B
- Product Type
- Power bank
- 3.3 cm x 2.2 cm x 7.2 cm
- 65 g
- Black/grey
- Output Connector Type
- Micro-USB Type B - on cable: Micro-USB
- Voltage Provided
- 5 V
- Max Electric Current
- 1 A
- Battery
- Lithium Ion - 2600 mAh
- Cables
- Micro-USB cable
- Standby Time
- Up to 11 h
- 1-year warranty
- Product Type
- Power bank
- Designed For
- Mobile phone
- 3.3 cm
- 2.2 cm
- 7.2 cm
- 65 g
- Enclosure Colour
- Black/grey
- Voltage Provided
- 5 V
- Output connectors
- 5 pin Micro-USB Type B
- Detachable Cable Connector Type
- Micro-USB Type B
- 1 A
- Technology
- Lithium Ion
- Capacity
- 2600 mAh
- Standby Time
- Up to 11 h
- Recharge Time
- 4.5 hour(s)
- Max Recharge Cycles
- 300
- Battery level indicator
- Cables Included
- Micro-USB cable
- Limited warranty - parts and labour - 1 year
