Your basket is empty
Emtec Power Clip U400 Android
Quicklinx: 9SZJWS00 Mfr#: ECCHA26U400AN
Extra juice right when you need it! The Power Clip is a back-up battery for your smartphone when it runs out of power.
EMTEC Power Clip U400 - power bank - Li-Ion
Power bank
3.3 cm x 2.2 cm x 7.2 cm
65 g
Output Connector Type
Micro-USB Type B - on cable: Micro-USB
Voltage Provided
5 V
Lithium Ion 2600 mAh
Standby Time
Up to 11 h
1 year warranty
Power bank
3.3 cm
2.2 cm
7.2 cm
65 g
Enclosure Colour
Black/grey
Voltage Provided
5 V
Output connectors
5 pin Micro-USB Type B
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
1 A
Lithium Ion
2600 mAh
Standby Time
Up to 11 h
Recharge Time
4.5 hour(s)
Max Recharge Cycles
300
Battery level indicator
Micro-USB cable
Limited warranty - parts and labour - 1 year
