The Elo Touch Solutions 3243L 32-inch Full HD open-frame touch monitor provides smooth dual-touch performance with IntelliTouch Plus surface acoustic wave technology. The 3243L touch monitor is 2.3 inches in total thickness and less than 1-inch in border width. The sleek mechanical design enables thinner and smaller kiosk design for various applications like retail, hotels, gaming, transportation and other commercial uses. The 3243L features a unique, injection-molded bezel with a virtually invisible water-resistant seal, making it a good choice for the rigors of public use. Narrow borders, multiple mounting options, and a USB touch interface add to the versatility of the 3243L.
- Elo 3243L - LED monitor - Full HD (1080p) - 32"
- LED-backlit LCD monitor - 32" - touchscreen
- Touch-screen
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 6.5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 73.54 cm x 5.8 cm x 44.3 cm
- 12.3 kg
- Localisation
- Worldwide
- UL, VCCI, C-Tick, BSMI, GOST, cUL, NOM, UL 60950, CB, CCC, IC, FCC, RoHS, WEEE, S Mark, KC
- 3-year warranty
- Display Type
- Diagonal Size
- 32"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Brightness w/touchscreen
- 315 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- 6.5 ms
- Vertical Refresh Rate
- 47 - 63 Hz
- Horizontal Refresh Rate
- 31 - 80 KHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, aspect control
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- LED edgelight system, IntelliTouch Plus Surface Acoustic Wave, OSD lock
- Black
- 73.54 cm x 5.8 cm x 44.3 cm - with stand
- 12.3 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Intellitouch SAW
- VGA , DVI-D , USB
Mechanical
- VESA Mounting Interface
- 400 x 200 mm
- IntelliTouch Surface Wave
- Mounting Kit
- Included
- MTBF
- 50,000 hour(s)
- Localisation
- Worldwide
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 55 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 1.4 Watt
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
