Your basket is empty
ELO 3243L Openframe 32" 1920x1080 6.5ms VGA DVI Touchscreen LED Large Format Display
Quicklinx: BFG9WS00 Mfr#: E589724
The Elo Touch Solutions 3243L 32-inch Full HD open-frame touch monitor provides smooth dual-touch performance with IntelliTouch Plus surface acoustic wave technology. The 3243L touch monitor is 2.3 inches in total thickness and less than 1-inch in border width. The sleek mechanical design enables thinner and smaller kiosk design for various applications like retail, hotels, gaming, transportation and other commercial uses. The 3243L features a unique, injection-molded bezel with a virtually invisible water-resistant seal, making it a good choice for the rigors of public use. Narrow borders, multiple mounting options, and a USB touch interface add to the versatility of the 3243L.
Elo 3243L - LED monitor - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32" - touchscreen
Touch-screen
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
350 cd/m²
Contrast Ratio
3000:1
Response Time
6.5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
73.54 cm x 5.8 cm x 44.3 cm
12.3 kg
Worldwide
UL, VCCI, C-Tick, BSMI, GOST, cUL, NOM, UL 60950, CB, CCC, IC, FCC, RoHS, WEEE, S Mark, KC
3 years warranty
Display Type
Diagonal Size
32"
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Brightness w/touchscreen
315 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
6.5 ms
Vertical Refresh Rate
47 - 63 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, aspect control
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
LED edgelight system, IntelliTouch Plus Surface Acoustic Wave, OSD lock
73.54 cm x 5.8 cm x 44.3 cm - with stand
12.3 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Intellitouch SAW
VGA , DVI-D , USB
Mechanical
Flat Panel Mount Interface
400 x 200 mm
IntelliTouch Surface Wave
Mounting Kit
Included
MTBF
50,000 hour(s)
Worldwide
Power Supply
Internal
55 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
1.4 Watt
Limited warranty - 3 years
20 - 80% (non-condensing)
