Go Create
You continuously evolve your content. Stream and record your finest gaming moments with HD60 S, and leverage the ultimate foundation to showcase what you’re really capable of.
Instant Performance
With a slick exterior, streamlined curves and striking LED status strip, HD60 S outperforms in appearance alone. But the real power lies within. Stunning 1080p60 quality leaves no doubt that you’re serious about your craft, while a state-of-the-art, reversible USB-C connector gets you hooked up in a snap. It’s plug 'n' play taken to the next level. Add voice with the built-in Live Commentary feature, and you're all set for the big show.
Instant Streaming
HD60 S features a reliable, high-performance USB 3.0 connection to bring Instant Gameview to an external capturing solution for the first time. Now, your stream is powered by superior low-latency technology that gets you up and running on Twitch or YouTube in no time.
Instant Recording
Want to show off your skills, showcase your highlights, or share your entire story as it unfolds? With HD60 S, wield the power of advanced GPU acceleration to seamlessly record hours of your gameplay. Then access your content right where you need it, and instantly create history.
Instant Creation
Customise your stream without limits. Add your webcam, overlays, alerts and more, and change your layout on the fly with scenes. Forget to hit record? No sweat. Simply slide back in time and capture every moment retroactively.
Instantly You
Capturing your gameplay is just the beginning. With frictionless performance, HD60 S gives you the edge so you can hone your production, and stand out from the rest. Your audience will notice.
Instantly ready
Being faster and more efficient makes a world of difference. Thanks to a reversible USB-C connector, HD 60 S doesn't make you think twice. You're hooked up within seconds, and stunning 1080p quality won't leave any doubt that you're about to get serious. -
Instant recording
HD 60 S is ready to save your most important moments, even if you didn't press the record button. With flashback recording, simply slide back in time on your PC and hit the record button retroactively. Seamlessly record hours of your best moments in perfect quality and access them directly right where you need them - you'll be instantly ready to create history. -
Instantly you
Capturing your gameplay is just the beginning. With frictionless performance, HD 60 S gives you the edge to let you focus and perfect your production. Your audience will notice.
- Elgato Game Capture HD 60 S - video capture adapter - USB 3.0
- Video capture adapter
- Interface Type
- USB 3.0
- 11.2 cm x 7.5 cm x 1.9 cm
- 106 g
- Video Input
- HDMI
- Video Modes
- 480p, 1080i, 576i, 576p, 720/60p, 1080/60p, 1080/30p, 720/30p
- Audio Input Support
- Standard
- OS Required
- Windows 10
- Interface Type
- USB 3.0
- 11.2 cm
- 7.5 cm
- 1.9 cm
- 106 g
Video
- Interface Type
- HDMI
- Video Modes
- Standard
- 1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio / video - HDMI output - 19 pin HDMI Type A
- Connections
- 1 x SuperSpeed USB 3.0 - 24 pin USB-C
- OS Required
- Windows 10
- System Requirements Details
- Core i5 RAM 4 GB
