Live smarter by knowing more about the place you care about most. With Eve Weather, Eve senses temperature, humidity, and air pressure.
Eve Weather is built to live outside, and with IPX3 water resistance, even a little rain won't hurt. Keep track of the weather at your actual home, and easily access your personal data right on your iPhone and iPad.
Improve your comfort
Live smarter by knowing more about the place you care about most. With Eve Weather, Eve senses temperature, humidity, and air pressure. -
Your personal weather
Eve Weather is built to live outside, and with IPX3 water resistance, even a little rain won't hurt. Keep track of the weather at your actual home, and easily access your personal data right on your iPhone and iPad. -
Gain insights
See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place. -
Easy setup
Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge. -
Advanced security
HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch. -
Simply elegant
The Eve family has been carefully designed to seamlessly blend into your home environment. This elegance extends to truly wireless operation: thanks to Bluetooth Smart technology, Eve is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
- Eve Weather - multipurpose sensor - Bluetooth 4.0
- Product Type
- Multipurpose sensor
- Environment
- Outdoor
- Sensor Type
- Temperature, humidity, air pressure
- Power Source
- Battery
- Connectivity
- Wireless - Bluetooth 4.0
- Supported Host Device OS
- iOS
- 7.9 cm x 3.2 cm x 7.9 cm
- Product Type
- Sensor Type
- Environment
- Outdoor
- Power Source
- Battery
- Connectivity Technology
- OS Required
- Apple iOS 9.1 or later
- iOS
- Water-resistant
- Measurement Accuracy
- ±0.3 °C
- Form Factor
- AA type
- Required Qty
- 2
- IPX3
- 7.9 cm
- 3.2 cm
- 7.9 cm
- -18 °C
- 55 °C
- 0 - 100%
