Product
Elgato Eve Weather Wireless Multipurpose Sensor - Bluetooth 4.0 LE
Quicklinx: CYV3WS00 Mfr#: 1EW109901001
Live smarter by knowing more about the place you care about most. With Eve Weather, Eve senses temperature, humidity, and air pressure.
Eve Weather is built to live outside, and with IPX3 water resistance, even a little rain won't hurt. Keep track of the weather at your actual home, and easily access your personal data right on your iPhone and iPad.
  • Improve your comfort
  • Your personal weather
  • Gain insights
    See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place.
  • Easy setup
    Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge.
  • Advanced security
    HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch.
  • Simply elegant
    The Eve family has been carefully designed to seamlessly blend into your home environment. This elegance extends to truly wireless operation: thanks to Bluetooth Smart technology, Eve is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
Eve Weather - multipurpose sensor
Multipurpose sensor
Sensor Type
Temperature, humidity, air pressure
Power Source
Wireless - Bluetooth 4.0 LE
Supported Host Device OS
iOS
7.9 cm x 3.2 cm x 7.9 cm
Multipurpose sensor
Sensor Type
Power Source
Apple iOS 9.1 or later
iOS
Water-resistant, outdoor usage
Thermostat
Measurement Accuracy
0.3 °C
Battery Required
2 x AA type
IPX3
7.9 cm
3.2 cm
7.9 cm
-18 °C
55 °C
0 - 100%
