Feel better in your home by getting the temperature just right. With Eve Thermo, set your perfect comfort level with a simple tap, and create schedules to automatically heat your home to match your daily routine.
Heat smarter
Upgrading your room to truly smart heating couldn't be simpler. Simply replace your existing radiator valve with Eve Thermo, and forget about manually controlling your temperature. All you have to do is set your desired comfort level, and Eve Thermo will take care of the rest. -
Create schedules
Easily match your heating to your daily routine with schedules. Choose one of the built-in presets, or customize different temperatures and times with a few simple taps. And because it's truly smart, Eve Thermo will know exactly when you expect to return home. -
Gain insights
See your heating patters and actual room temperature at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place.
- Eve Thermo - radiator thermostat - Bluetooth 4.0
- Product Type
- Radiator thermostat
- Power Source
- Battery
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Siri - indirect
- Connectivity
- Wireless - Bluetooth 4.0
- Supported Host Device OS
- iOS
- 5.4 cm x 6.7 cm x 8.5 cm
- Product Type
- Power Source
- Battery
- Connectivity Technology
- OS Required
- Apple iOS 9.1 or later
- iOS
- Internet of Things (IoT) Compatible
- Platform
- Apple HomeKit
- Communications Type
- Product-to-product
- Communications Technology
- Bluetooth Low Energy (LE)
- Siri
- Voice Controlled
- Indirect
- Form Factor
- AA type
- Required Qty
- 2
- 5.4 cm
- 6.7 cm
- 8.5 cm
