Elgato Eve Energy Switch & Power Meter
Quicklinx: D4M2WS00 Mfr#: 1EE101101000
Type: Power / energy metre
Compatible With: Siri
More than 50 in stock
£41.66 ex VAT
£49.99 inc VAT
Eve Energy
Empower your appliances.
Switch appliances on and off from anywhere. Know how much power they’re using. And have them come to life on their own. Everything about Eve Energy says: you’re in control.
Talk or tap to control.
Hands tied? Already comfortable? Switch on any appliance in your home with a simple tap or Siri voice command.
Access on the go.
Your home hub will keep you connected to your abode whether you’re strolling around the block, or exploring the world.
Automate everyday essentials.
Set timers for lights, humidifiers, fans, and other vital devices. Then go about your usual business while they get on with theirs.
Watch those watts.
Curiosity. Economy. Conservation. Reasons to monitor power consumption and projected cost are aplenty. Eve Energy gives you the insight to embrace yours.
Set the perfect scene.
"Hey Siri, it's bedtime."
Scenes enable multiple accessories to work in concert. So you can create a scene called "Bedtime" that turns on your bedside lamp via Eve Energy, locks your doors, and shuts your shades – all with one tap or voice command.
Command on demand.
Set scenes in a flash via Siri, your Control Center, or Apple Watch. Easily engage accessories using the Home app on your iPhone, iPad, or iPod touch. And to see concise records, gain insights, and enjoy full control of your connected home, look no further than the Eve app.
Safe as houses.
Eve accessories are exclusively HomeKit-enabled. Even when accessing your home remotely via your home hub, data is end-to-end encrypted and stored on your iPhone or iPad. Superior privacy, advanced security, and absolute peace of mind – it’s all here.
  • Improve your comfort
    Live smarter by knowing more about the place you care about most. With Eve Energy, switch your devices on or off with a simple tap or using Siri, and instantly see how much energy your devices are using.
  • Gain insights
    See your energy consumption at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place.
  • Easy setup
    Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge.
  • Use your voice
    Use Siri on your iPhone, iPad, or iPod touch to control your devices connected to Eve Energy with just your voice. Assign custom names to your devices using the Eve app, and group them to access them simultaneously.
  • Advanced security
    HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch.
  • Simply elegant
    The Eve family has been carefully designed to seamlessly blend into your home environment. Bluetooth Smart technology makes setup a breeze, with no need for complicated WiFi setup and energy efficient, low power operation.
Eve Energy - power / energy metre
Environment
Indoor
Sensor Type
Functions
Power measuring, switching
Internet of Things (IoT) Platform
Apple HomeKit
Intelligent Assistant
Siri
Wireless - Bluetooth
United Kingdom
7.2 cm x 7.2 cm x 7.1 cm
Sensor Type
Environment
Indoor
Functions
Timer
Platform
Apple HomeKit
Siri
United Kingdom
Nominal Voltage
AC 100 - 240 V
Power Provided
2500 Watt
TUV Rheinland, BS 1363
7.2 cm
7.2 cm
7.1 cm
Brand: Elgato
Price Range Ex VAT: 0 - 50
