Elgato Eve Door/Window Wireless Contact Sensor with Apple HomeKit Technology
Quicklinx: BDLYWS00 Mfr#: 1ED109901000
Eve Door & Window
Live smarter by knowing more about the place you care about most. Eve Door & Window understands whether your door or window is open or closed. See the current open/closed state at a glance and view statistics on time & duration to make smarter choices.
Taking advantage of Apple's revolutionary HomeKit technology, Eve offers unparalleled ease of use, advanced security, and tight integration with Siri. Eve Door & Window connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge.
About Eve
With Eve, see your home at a glance, right on your iPhone and iPad. The Eve family of HomeKit accessories gathers data on air quality, temperature, humidity, air pressure, energy consumption and more. Gain insights that help you improve your comfort, and make your home a smarter place. Use the free Eve app to view all data collected by Eve and control all accessories featuring HomeKit technology.
  • Know your home: Eve Door & Window understands whether your door or window is open or closed
  • Gain insights: view statistics on time & duration and make smarter choices
  • HomeKit-enabled: unparalleled ease of use and advanced security
  • Works with Siri: ask for the current open/closed state
  • Truly wireless: powered by a long-lasting, replaceable battery
  • Easy setup: direct connection using Bluetooth Smart technology, no hub or gateway required
*iPhone not included
  • Improve your comfort
    Live smarter by knowing more about the place you care about most. With Eve Door & Window, Eve understands whether your door or window is open or closed.
  • Gain insights
    See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place.
  • Simply elegant
    The Eve family has been carefully designed to seamlessly blend into your home environment. This elegance extends to truly wireless operation: thanks to Bluetooth Smart technology, Eve is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
  • Easy setup
    Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge.
  • Use your voice
    Use Siri on your iPhone, iPad, or iPod touch to ask for temperature or humidity.
  • Advanced security
    HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch.
Eve Door & Window - door and window sensor - Bluetooth 4.0
Door and window sensor
Wireless - Bluetooth 4.0
Supported Host Device OS
iOS
iOS
1/2 AA battery
