Avea - Dynamic Mood Light
Transform your home with beautiful dynamic light moods. Control your ambience from your iPhone, iPad, or Apple Watch, and unwind in one of the carefully crafted settings with subtly changing light.
- Transform your home with beautiful dynamic light moods
- Control your ambience from your iPhone, iPad, or Apple Watch
- Rise and shine with the built-in wake-up light scene
- Direct connection using Bluetooth Smart technology
- Connect more than one Avea to coordinate their lighting
Supported devices
- iPhone 4S or later, iPod touch (5th generation), iPad mini or iPad (3rd generation or later); with iOS 7.1 or later
- Apple Watch
Technical Specifications
- 7 W LED / 430 lm
- 3000 K / warm white
- E27 / E26 / A21
- 110-240 V
- Energy efficiency class: A
- Energy consumption: 7 kWh / 1000 h
- Operating temperature: 0° - 50° C (32° - 122° F)
Rise and shine
After a relaxing evening, simply set your alarm using the built-in wake-up light scene. With Avea, rise and shine along a natural sunrise, right in your bedroom. -
Wrist-controlled
Avea on Apple Watch makes it easier than ever to pick the perfect lighting for your mood. Simply raise your wrist to view the current status of Avea at a glance, and effortlessly transform your home with a simple tap. -
Smart technology
Avea connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring additional gateways or bridges. But it does not stop there: once you have chosen a light scene, the smart LED lightbulb will take care of the rest, not requiring a constant connection to your iPhone or iPad.
- Elgato Avea - LED light bulb - shape: A21 - E26 / E27 - 7 W - warm white light - 3000 K
- Light Source Type
- LED light bulb
- Shape
- A21
- Socket Type
- E26 / E27
- Wattage
- 7 W
- Energy Efficiency Class
- A
- Colour of Illumination
- Warm white light
- Colour Temperature
- 3000 K
- Luminous Power
- 430 lumens
- Voltage Required
- AC 110 - 240 V
Light Source
- LED light bulb
- Shape
- A21
- Socket Type
- E26 / E27
- Wattage
- 7 W
- A
- Energy Consumption per 1000h
- 7 kWh
- Warm white light
- 3000 K
- Luminous Power
- 430 lumens
- iOS compatible, controlled via Bluetooth 4.0
Power Requirements
- Voltage Required
- AC 110 - 240 V
- 0 °C
- 50 °C
