Eizo IPS Monitor 24" 1920 x 1080 5 MS DVI HDMI LED
Quicklinx: BWCYWS00 Mfr#: EV2450-BK
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£211.47 ex VAT
£253.76 inc VAT
The monitor features a "fusion" design that combines EIZO's own EcoView technologies for reduced power consumption and improved visual ergonomics inside an extremely compact cabinet.
  • World's thinnest bezels for multi-monitor environments
    The monitor features 1 mm ultra-slim bezels on the sides and top with black borders of 4.3 mm and a depth of a mere 47.9 mm. This makes for an attractive design that blends in with the desktop and reduces eye movement in a multi-monitor setup.
  • Clear view from all angles
    The monitor uses an LED-backlit IPS (in-plane switching) LCD panel with 178° viewing angle that minimizes color shift and contrast changes when viewing the screen at an angle.
  • Auto brightness control
    To prevent eye fatigue, a brightness sensor called Auto EcoView detects the changes in the ambient brightness that occurs throughout the day and automatically adjusts the screen to the ideal brightness level.
  • Adjustable to less than 1% of maximum brightness
    In a dimly-lit work environment, a monitor with low brightness settings is more comfortable to use. With its LED backlight, thmonitor is adjustable to 1 cd/m2 which is less than 1% of the maximum.
  • Flicker-free images
    Due to the way brightness is controlled on LED backlights, a small number of people perceive flicker on their screen which causes eye fatigue. The FlexScan EV series utilizes a hybrid solution to regulate brightness and make flicker unperceivable without any drawbacks like compromising color stability.
  • Less blue light reduces eye fatigue
    In the visible light spectrum, blue light has wave lengths adjacent to ultraviolet light. Compared to the factory preset setting of 6,500 K of typical LCD monitors, Paper Mode is closer to the spectral distribution with long reddish wavelengths so it reduces the amount of blue light, a cause of eye fatigue, and helps prevent eyestrain when reading documents.
  • LED backlights - less power, longer life
    Compared to CCFL backlights, LED backlights last longer and consume less power. They are also mercury-free for minimal environmental impact.
  • Reduce power by up to 30%
    A feature called EcoView Optimizer 2 saves energy by up to 30% by reducing the backlight brightness and increasing the gain. To maintain image quality, EcoView Optimizer 2 only boosts the gain with a screen consisting mostly of dark content because the accompanying reduction in brightness is almost unperceivable.
  • Presence sensor for energy savings
    A presence sensor called EcoView Sense prompts the monitor to switch to power save mode when you are absent and then power on again when you return. It even works in a multi-monitor setup so all monitors remain on when you're at your desk.
EIZO FlexScan EV2450-BK - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
USB 3.0 hub
Panel Type
IPS
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
53.76 cm x 23.3 cm x 47.35 cm
6.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
FCC Class B certified, TUV GS, TUV S, CB, ICES-003 Class B, CCC, TUV Ergo, RoHS, WEEE, PSE Mark, GOST-R, cTUVus, J-MOSS, VCCI Class B, China RoHS, RCM
5-year warranty
Display Type
Energy Class
Class A+
25 kWh
17 W
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
31 - 81 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
sRGB colour management, HDCP, BrightRegulator, Auto EcoView, EcoView Sense
53.76 cm x 23.3 cm x 47.35 cm - with stand
6.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , HDMI (HDCP) , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
344
Rotation Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable
Power Supply
Internal
47 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 53.76 cm - depth: 23.3 cm - height: 47.35 cm - weight: 6.2 kg , Without stand - width: 53.76 cm - depth: 4.79 cm - height: 31.76 cm - weight: 3.8 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 5 years
5 °C
35 °C
20 - 80% (non-condensing)
Eizo IPS Monitor 24 Bundle deal on Eizo IPS Monitor 24" 1920 x 1080 5 MS DVI HDMI LED
£310.64
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Eizo
Price Range Ex VAT: 150 - 300
