Eizo FlexScan 21.3" 1600x1200 6ms VGA DVI DisplayPort IPS LED Monitor
Quicklinx: B4DJWS00 Mfr#: S2133-BK
Diagonal Size: 21.3in
Max Resolution: 1600 x 1200
Response Time: 6ms
Speakers: None
Interfaces: DisplayPort, DVI, VGA (HD-15)
£542.41 ex VAT
£650.89 inc VAT
With its IPS panel and 1600 x 1200, resolution, the FlexScan S2133 is ideal for businesses and control rooms that need to display a large volume of data as well as for CAD and other design work that require brilliant color display.
  • Square format with ample space
    With a 21.3-inch screen and a 1600 x 1200 native resolution, the FlexScan S2133 displays a large volume of information so you can scroll less and work more efficiently.
  • Viewing comfort with an ergonomic stand
    Adjust the screen to the most comfortable position with 82 mm height adjustment, 40-degree tilt, 70-degree swivel, and 90-degree rotation for portrait mode. Compatibility with VESA mounting standards allows the monitor to be removed from the stand for mounting on a movable arm or wall bracket.
  • Optimized brightness with Auto EcoView
    The Auto EcoView ambient brightness sensor on the front of the monitor measures ambient light and optimizes the screen's brightness so the screen is never too bright or too dark. This reduces both eye strain and the monitor's energy consumption.
  • Closely simulates documents and books
    Paper mode produces tones and contrast similar to those of printed paper. Together with the Auto EcoView ambient brightness sensor, paper mode makes reading documents and ebooks more comfortable and reduces eyestrain.
  • Good visibility in bright places
    With a maximum brightness of 420 cd/m2 and a contrast ratio of 1500:1, the screen remains visible under daylight conditions and brightly lit rooms.
  • USB hub
    A USB hub with one upstream and two downstream ports is included.
  • Supports HDCP
    The DisplayPort and DVI-D 24 pin connectors and HDCP compliant. By connecting to an HDCP enabled computer, you can display digital copyright protected contents from digital streams and Blu-ray.
  • Energy savings across the network
    EIZO's EcoView NET power management software provides centralized control over the power settings of monitors on a network. With EcoView NET, a systems administrator can confirm the settings for each monitor on the network, turn the power on or off, and if necessary, take measures to combat eye fatigue such as adjust the brightness or activate Auto EcoView.
  • IPS panel with wide viewing angles
    The IPS (in-plane switching) panel offers 178-degree viewing angles to minimize color shift and contrast when viewing the screen at an angle. This ensures stable and consistent display when two or more people view the screen at once or in a multi-monitor environment. A non-glare screen reduces eye fatigue by dissipating reflective light that otherwise makes the screen difficult to see.
  • 10-bit gamma correction
    This technology helps achieve accurate color by converting the 8-bit PC data to 10-bit, and assigning the ideal gamma values with a 10-bit look-up table (LUT) then returning the data to 8-bit format for display.
  • LED backlight
    With an energy-saving LED backlight, the FlexScan S2133 uses only 13 watts during typical operation. The LED backlight does not contain any mercury for minimal environmental impact when the monitor is eventually disposed of.
  • Consistent color display
    The gamma, color temperature, and other parameters are adjusted to the proper values on the assembly line. This minimizes variation in color display for consistency in a multi-monitor setups and large scale installations.
  • Clear video display
    An overdrive circuit that reduces gray-to-gray response time to just 6 ms when watching video. This greatly reduces ghosting and blurring that is caused by high motion scenes ensuring moving images look clean and sharp.
  • Getting connected
    Three input terminals are included - DisplayPort, DVI-D, and D-Sub. The DisplayPort cable can be quickly affixed and detached which makes it convenient for connecting the monitor to a notebook computer. With DisplayPort, you can easily build a multi-monitor environment by using a graphics board that has multiple DisplayPort connectors or a DisplayPort multi-display adapter.
EIZO FlexScan S2133-BK - LED monitor - 21.3"
LED-backlit LCD monitor - 21.3"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
4:3
Native Resolution
1600 x 1200
Pixel Pitch
0.27 mm
Brightness
420 cd/m²
Contrast Ratio
1500:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
46.5 cm x 20.85 cm x 45.3 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, TUV S, CB, CCC, TUV Ergo, DDC/CI, RoHS, WEEE, cTUVus, VCCI Class B, EAC, China RoHS, RCM, CAN ICES-3 Class B, TUV Rheinland, HDCP 1.3, HDCP 1.4
5-year warranty
Display Type
Diagonal Size
21.3"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
4:3
Native Resolution
1600 x 1200
Pixel Pitch
0.27 mm
Brightness
420 cd/m²
Contrast Ratio
1500:1
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
24 - 80 kHz
Video Bandwidth
162 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, saturation, gamma correction, colour temperature, phase, clock, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Swedish, Spanish, Japanese
sRGB colour management, Fine Contrast, Auto EcoView, 10-bit gamma, Composite Sync
46.5 cm x 20.85 cm x 45.3 cm - with stand
8.6 kg
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
40
Swivel Angle
70
Rotation Angle
90
Height Adjustment
82 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D - 2 m , 1 x VGA cable - 1.8 m , 1 x USB cable - 1.8 m
Security Slot Type
Kensington security slot
Power Supply
Internal
13 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Drivers & Utilities, EIZO ScreenSlicer, ScreenManager Pro for DDC
Dimensions & Weight Details
With stand - width: 46.5 cm - depth: 20.85 cm - height: 45.3 cm - weight: 8.6 kg , Without stand - width: 46.5 cm - depth: 6.4 cm - height: 36.1 cm - weight: 5.6 kg
ENERGY STAR Certified
Limited warranty - 5 years
5 °C
35 °C
20 - 80% (non-condensing)
Eizo FlexScan 21.3 Bundle deal on Eizo FlexScan 21.3" 1600x1200 6ms VGA DVI DisplayPort IPS LED Monitor
£641.58
Response Time: 6ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Eizo
Price Range Ex VAT: 500 - 750
