EE 4GEE Wifi Mini 2 (2018)
Quicklinx: F5K6WS00 Mfr#: EE70
Keep yourself connected
The 4GEE WiFi Mini router is the ideal way to keep connected with all your devices. Connect up to 20 devices at any one time to make the most of your tech. You can create your own secure 4G WiFi network wherever you are – never rely on open networks again.
Stay online for longer
With up to 8 hours of uncharged use, 4GEE WiFi Mini will keep you online for even longer. Keep all your tech connected with devices and a network you can rely on.
Compact and portable
The 4GEE WiFi Mini router has been redesigned in a super-compact, rectangular, lighter size and can be easily transported with you – ideal for those with an on-the-go lifestyle. Keep all your devices connected on EE, the UK network with 4G in more places than any other.
Super Speedy
The all new and improved 4GEE WiFi Mini will have you up and running with access to amazingly fast UK 4G speeds.
POCKET the slicker 4GEE WiFi Mini and create your own super-fast secure 4G WiFi when out and about. Connect up to 20 devices - inc UBS type C port. 4GEE WiFi Mini
  • Size: 62.5 x 92 x 13.3mm
  • Weight: 85g
  • Compact and portable
    The 4GEE WiFi Mini is significantly smaller and fits into a pocket, allowing customers to easily carry their own secure Wi-Fi connection with them.
  • Keep going for longer
    The power of the 4GEE WiFi Mini is matched by the performance of its hard-working battery, offering long hours, with an impressive long hours stand-by time. With the 4G coverage, you can rely on both the battery and their network to keep you online for longer, wherever you are.
4GEE WiFi Mini - 2018 Edition - mobile hotspot - 4G
Mobile hotspot
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
2150 mAh - up to 8 hrs
9.2 cm x 6.25 cm x 1.33 cm
85 g
Mobile hotspot
External
Enclosure Colour
Modem
Wireless
256 MB
Wireless
1 x USB
1 x USB cable
EN 50581:2012, EN 62479:2010, RoHS 2011/65/EU, EN 62311:2008, EN 55032:2015, EN 300 328 V2.1.1, EN 301 489-1 V2.1.1, EN 301 489-17 V3.1.1, RED 2014/53/EU, EN 301 908-2 V11.1.2, EN 301 908-13 V11.1.2, EN 301 893 V2.1.1, EN 300 440-2 V2.1.1, EN 301 489-52 V1.1.0, EN 50566:2017, EN 50663:2017, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 301 908-1 V11.1.1
9.2 cm
6.25 cm
1.33 cm
85 g
