EE 4GEE Router
EE 4GEE Router
Quicklinx: F5K7WS00 Mfr#: HH70
  • IEEE 802.11n
£108.33 ex VAT
£129.99 inc VAT
Express delivery Order within the next 15 hours for delivery tomorrow
The ideal alternative to slow home broadband
Are you struggling with slow home broadband speeds in your area? Maybe you’re having trouble getting fixed broadband installed or staying somewhere temporarily. Our 4GEE Home router could be the answer.
Delivered through 4GEE on the UK’s fastest network, you can get average speeds of 31Mb/s in some places, that’s faster than standard fibre broadband.
Superfast speeds
If you live in a slow speed area, our 4GEE Home Router can give you faster speeds over the 4G network.
No need for a landline
There’s no wait to get a landline installed, so you can start using your 4GEE Home router instantly.
Set-up in seconds
There’s no engineer visit or wait to get installed. Just plug in the power to get connected instantly.
30m WiFi range
With its increased range, your WiFi signal is distributed effectively all
Connect up to 32 devices
With the ability to connect up to 32 devices, you can keep the whole home connected on multiple devices.
LAN Port
4GEE Home router includes a Local Area Network port for improved connectivity
  • Superfast speeds
    If you live in a slow speed area, EE's 4GEE Home Router can give you faster speeds over the 4G network.
  • No need for a landline
    There's no wait to get a landline installed, so you can start using your 4GEE Home Router instantly.
  • Set-up in seconds
    There's no engineer visit or wait to get installed. Just plug in the power to get connected instantly.
  • 30m Wi-Fi range
    With its increased range, your Wi-Fi signal is distributed effectively all through your home.
  • Connect up to 32 devices
  • LAN port
    4GEE Home router includes a Local Area Network port for improved connectivity.
4GEE Home Router - wireless router - WWAN - 802.11a/b/g/n/ac - desktop
Wireless router - wireless cellular modem
Enclosure Type
Desktop
Cellular Protocol
LTE
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Firewall protection, MAC address filtering, reset button
White
14.6 cm x 14.6 cm x 3.2 cm
350 g
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Max Range Indoors
30 m
Authentication Method
Radio Service Set ID (SSID)
Built-in Devices
Led panel
Status Indicators
Power, LAN, Wi-Fi
Communications
Wireless cellular modem
Cellular Protocol
LTE
LAN: RJ-45 , USB:
Expansion Slots
1 (total) / 1 (free) x SIM
External power adapter
Enclosure Colour
White
1 x network cable
14.6 cm
14.6 cm
3.2 cm
350 g
Type: Wireless router
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Brand: EE
Price Range Ex VAT: 100 - 150
