Product
Edimax Wireless Pan &Tilt Network Camera
Quicklinx: 98Y1WS00 Mfr#: IC-7001W
The Edimax IC-7001W pan and tilt network camera is a versatile monitoring device ideal for monitoring your home in daylight and at night. With Edimax Plug-n-View technology, no complicated setup is required and you can easily connect the camera to the cloud and monitor remotely from a smartphone, tablet or laptop. It can monitor a large area with its pan and tilt design, and its motion-triggered snapshot-to-email function ensures that you capture every criminal event. The IC-7001W comes with two network interfaces (Fast Ethernet & wireless), making it perfect for any home monitoring application.
Plug-n-View for 24/7 Easy Remote Monitoring
Edimax Plug-n-View technology makes it easy for you to keep an eye on the safety of your home, family, pets, and assets wherever you go. With Plug-n-View technology, you can connect your Edimax network camera to the cloud in a few simple steps and access it remotely with a smartphone, tablet, or computer no matter where you are.
Night Vision
The built-in IR (infrared) LEDs and light sensor make this Edimax network camera perfect for capturing crisp and clear videos in low light conditions. It automatically switches to night vision mode and turns on the IR LEDs to illuminate the monitored area when it gets dark, ensuring that you get video footage of critical moments both in daylight and at night.
Motorized Pan & Tilt
With the ability to pan ±355 degrees and tilt ±120 degrees, this Edimax network camera gives you a wider viewing angle than the average network camera. You can control the camera's pan and tilt remotely via a web browser and smartphone app.
Motion-Triggered Snapshots-or-Recording To Email
The powerful multi-area motion detection system built into this network camera ensures that you have evidence of a criminal event. You can pre-define multiple areas in the monitored range for motion detection; and when motion is detected in the specified areas, the network camera will produce snapshots or video footage of the event immediately.
SOFTWARE FEATURES
Easy remote monitoring via iPhone, iPad, Android, PC & Mac
Multi-area motion detection
Recording upon detected motion
Sends motion-detected snapshots to email and FTP
Plug-n-View for 24/7 Remote Monitoring with free EdiView app on iPhone®, iPad® or Android® or EdiView software on computers
Night Vision with infrared LEDs and auto light sensor
Motorized Pan & Tilt for a wider viewing angle
Multi-Area Motion Detection triggers snapshots or recording and sends to email and ftp
Two-Way Audio with built-in microphone and audio out port for speaker conneciton, for easy on-site communication and alerts
Wireless & Ethernet connection for flexible placement
Easy Setup & WPS Support
  • Plug-n-View for 24/7 easy remote monitoring
  • Night vision
  • Motorized pan and tilt
  • Motion-triggered snapshots-or-recording to email
Edimax IC-7001W - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: two-way audio capability, built-in microphone
9 cm x 11.2 cm x 11.6 cm
265 g
Wired, wireless
Camera
Colour - Day&Night
Optical Sensor Type
CMOS 0.3 MP
Minimum Illumination
1 lux
Focal Length
3.6 mm
Lens Iris
F/2.0
Panning Range (degree)
-355 to +355
Tilting Range (degree)
-120 to +120
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 12 V
Motion sensor, upgradable firmware, Wi-Fi Protected Setup (WPS), Plug-n-View
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wired, wireless
9 cm
11.2 cm
11.6 cm
265 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
AVI, MJPEG
1 lux
RAM
4 MB
Flash Memory
64 MB
Image Sensor
0.3 MP CMOS
Lens Construction
Focal Length
3.6 mm
Lens Iris
F/2.0
Panning
Range (degree)
-355 to +355
Titling
Range (degree)
-120 to +120
Network Interface
Network Protocols
DDNS, DHCP, FTP, HTTP, SMTP, RTSP, UPnP, Bonjour
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - output , 1 x microphone - input
1 x network cable - external
FCC, RoHS
Power Requirements
DC 12 V
Power adapter - external
Microsoft Windows 2000/XP/Vista/7/8
System Requirements Details
Windows XP/Vista/7/8 - Pentium 4 - 2.4 GHz HD 128 MB
Relative Humidity (operating)
