Edimax Wireless HD Outdoor Day/Night Cloud Camera
Quicklinx: BYR2WS00 Mfr#: IC-9110W
  • microSD Card
  • microSDHC Card
The Edimax IC-9110W is an innovative outdoor network camera with a unique two-piece design featuring an outdoor network camera and an indoor Wi-Fi unit, providing freedom to place the camera anywhere you need. It’s a versatile monitoring device ideal for monitoring your home, shop or factory during the daytime or at night. With Edimax Plug-n-View technology, no complicated setup is required and you can easily connect the camera to the cloud and monitor remotely from a smartphone, tablet or laptop.
The IC-9110W additionally features a motion detection system and a built-in a microSD/SDHC card slot. Motion detection can be configured according to user-defined areas. Motion-triggered recording ensures that you capture any illicit or suspicious activity and the wireless user interface allows for easy installation and monitoring.
  • Innovative Outdoor Network Camera with indoor Wi-Fi Unit, providing more freedom to place the camera anywhere
  • Plug-n-View for 24/7 Remote Monitoring with free EdiView II app on iPhone®, iPad® or Android® and 16 channel viewer software for computers
  • 720p HD Video Quality with high resolution and rich detail
  • Night Vision with infrared LEDs, ICR (IR Cut Filter Removal) and auto light-sensor
  • Motion Detection triggers recording and sends to email and ftp
  • Push Notifications & Video Alert with event videos
  • Indoor Wi-Fi Unit with microSD/SDHC Card Slot for local storage and better security
  • Industrial Durability Outdoor Camera with IP66 waterproof rating and anti-cut bracket system
  • Wireless & Ethernet Connection for flexible placement, and compatible with IEEE 802.11b/g/n products
  • Easy Setup with EdiView II mobile app and additional WPS support
  • Edimax Plug-n-View
    Edimax Plug-n-View technology makes it easy for you to keep an eye on the safety of your home, family, pets, and assets wherever you go. With Plug-n-View technology, you can set up your Edimax network camera in a few simple steps. The camera also connects to the cloud automatically, so you can access it remotely with a smartphone, tablet, or computer no matter where you are.
  • Wide angle, high quality videos
    The Edimax IC-3115W is built with a wide lens that covers a viewing angle of 74.8 degrees, making it suitable for capturing video footage of a wide area with a single network camera. With a 1.3 megapixel CMOS sensor, this network camera is able to capture SXVGAvideos at 30 frames per second.
  • Motion-triggered snapshots
    The IC-3115W is designed with a powerful multi-area motion detection system. When motion is detected in the specified areas, the network camera will immediately take a snapshot of the detected motion and send the snapshot to the user via email or FTP.
Edimax IC-9110W - network surveillance camera
Network surveillance camera - fixed - outdoor - waterproof
6.35 cm x 14.78 cm x 6.35 cm
330 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
Motion Detection
Video Modes
720p
Optical Sensor Type
CMOS
Focal Length Control
Fixed focal
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 12 V
Motion Detection Technology, light sensor, infrared cut filter, Wi-Fi Protected Setup (WPS), reset button
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Wired, wireless
6.35 cm
14.78 cm
6.35 cm
330 g
Camera
Colour - Day&Night - fixed - outdoor - waterproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Modes
720p
Infrared LEDs
20
Infrared Distance
15 m
Video Capture
1280 x 720 @ 24 fps , 640 x 360 @ 30 fps , 320 x 176 @ 30 fps
RAM
128 MB
Flash Memory
8 MB
Image Sensor
CMOS
Lens Construction
Fixed focal
Lens Iris
F/2.0
Network Interface
Network Protocols
DHCP, DNS, FTP, HTTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, IPv4, RTCP, PPPoE, SNTP
Supported Memory Cards
microSD Card, microSDHC Card
Antenna, indoor main unit
1 x network cable - external
FCC
Power Requirements
DC 12 V
Power adapter - external
Software Included
Drivers & Utilities
Relative Humidity (operating)
