The Edimax IC-9110W is an innovative outdoor network camera with a unique two-piece design featuring an outdoor network camera and an indoor Wi-Fi unit, providing freedom to place the camera anywhere you need. It’s a versatile monitoring device ideal for monitoring your home, shop or factory during the daytime or at night. With Edimax Plug-n-View technology, no complicated setup is required and you can easily connect the camera to the cloud and monitor remotely from a smartphone, tablet or laptop.
The IC-9110W additionally features a motion detection system and a built-in a microSD/SDHC card slot. Motion detection can be configured according to user-defined areas. Motion-triggered recording ensures that you capture any illicit or suspicious activity and the wireless user interface allows for easy installation and monitoring.
- Innovative Outdoor Network Camera with indoor Wi-Fi Unit, providing more freedom to place the camera anywhere
- Plug-n-View for 24/7 Remote Monitoring with free EdiView II app on iPhone®, iPad® or Android® and 16 channel viewer software for computers
- 720p HD Video Quality with high resolution and rich detail
- Night Vision with infrared LEDs, ICR (IR Cut Filter Removal) and auto light-sensor
- Motion Detection triggers recording and sends to email and ftp
- Push Notifications & Video Alert with event videos
- Indoor Wi-Fi Unit with microSD/SDHC Card Slot for local storage and better security
- Industrial Durability Outdoor Camera with IP66 waterproof rating and anti-cut bracket system
- Wireless & Ethernet Connection for flexible placement, and compatible with IEEE 802.11b/g/n products
- Easy Setup with EdiView II mobile app and additional WPS support
Edimax Plug-n-View
Edimax Plug-n-View technology makes it easy for you to keep an eye on the safety of your home, family, pets, and assets wherever you go. With Plug-n-View technology, you can set up your Edimax network camera in a few simple steps. The camera also connects to the cloud automatically, so you can access it remotely with a smartphone, tablet, or computer no matter where you are. -
Wide angle, high quality videos
The Edimax IC-3115W is built with a wide lens that covers a viewing angle of 74.8 degrees, making it suitable for capturing video footage of a wide area with a single network camera. With a 1.3 megapixel CMOS sensor, this network camera is able to capture SXVGAvideos at 30 frames per second. -
Motion-triggered snapshots
The IC-3115W is designed with a powerful multi-area motion detection system. When motion is detected in the specified areas, the network camera will immediately take a snapshot of the detected motion and send the snapshot to the user via email or FTP.
- Edimax IC-9110W - network surveillance camera
- Network surveillance camera - fixed - outdoor - waterproof
- 6.35 cm x 14.78 cm x 6.35 cm
- 330 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 720p
- Optical Sensor Type
- CMOS
- Focal Length Control
- Fixed focal
- Lens Iris
- F/2.0
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable - external
- Voltage
- DC 12 V
- Motion Detection Technology, light sensor, infrared cut filter, Wi-Fi Protected Setup (WPS), reset button
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Wired, wireless
- 6.35 cm
- 14.78 cm
- 6.35 cm
- 330 g
Camera
- Colour - Day&Night - fixed - outdoor - waterproof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- Infrared LEDs
- 20
- Infrared Distance
- 15 m
- Video Capture
- 1280 x 720 @ 24 fps , 640 x 360 @ 30 fps , 320 x 176 @ 30 fps
- RAM
- 128 MB
- Flash Memory
- 8 MB
Image Sensor
- CMOS
Lens Construction
- Fixed focal
- Lens Iris
- F/2.0
- Network Interface
- Network Protocols
- DHCP, DNS, FTP, HTTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, IPv4, RTCP, PPPoE, SNTP
- Supported Memory Cards
- microSD Card, microSDHC Card
- Included Accessories
- Antenna, indoor main unit
- Cables Included
- 1 x network cable - external
- FCC
- Power Requirements
- DC 12 V
- Power Device
- Power adapter - external
- Software Included
- Drivers & Utilities
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
