Edimax Wi-Fi 150Mbps Mini USB Adapter
Quicklinx: 71JHWS00 Mfr#: EW-7811UN
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£6.30 ex VAT
£7.56 inc VAT
EW-7811Un is a nano USB wireless adapter that supports maximum range and speed. Despite the size, this tiny USB adapter supports higher data rate of up to 150Mbps when connecting with wireless 802.11n device which is 3 times faster than your normally 11g connection. You can just plug it into computer's USB port and enjoy incredible high-speed wireless network access. This is for sure a trendy piece of upgrade you can make to your wireless network.
  • Complies with wireless 802.11n standards with data rate up to 150Mbps
    EW-7811Un complies with wireless IEEE802.11b/g/n standards. As being built with the wireless technology, the EW-7811Un can increase your wireless coverage up to 3 times as much and greatly help reduce "dead spots" compared to your old 11g adapter. The transmission data rate can go up to 150Mbps when connected to a 802.11n device, with signal travel further and connection a lot more stable compared to your previous 802.11g network .
  • Supports green WLAN
    EW-7811Un has adapted a clever protocol in smart transmission power control. The adapter smartly adjusts transmission output by distance and CPU offload to help reduce power consumption when wireless is idle. With the green WLAN technology, the power consumption can be reduced up to 20%-50%. The adapter does not just provide you with the best wireless technology in the world, it also care for the environment by using less energy and your pocket by saving up on your electric bills.
  • Supports WPS (Wi-Fi Protected Setup)
    Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of a wireless network. This wireless USB adapter supports software WPS-compatible configuration. By pressing 2 buttons, your wireless network is immediately secured providing your wireless router will also support this great easy function.
  • Portable and compact design
    EW-7811Un is a small wireless adapter. The compact design of EW-7811Un is convenient to carry for all mobile users. It also means you will not be able to accidentally snap your USB adapter anymore as it is hidden very well once it is plugged into the USB port.
Edimax EW-7811Un - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
1.5 cm x 1.9 cm x 0.7 cm
802.11b/g/n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, USB 1.1, USB 2.0, IEEE 802.11n, Wi-Fi Protected Setup
Microsoft Windows Vista / XP / 7
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link OK, link/activity
Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Green WLAN
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC, RoHS
Software Included
Drivers & Utilities, EZmax Setup Wizard
Additional Requirements
USB port (compatible with 2.0 specification)
1.5 cm
1.9 cm
0.7 cm
10 - 90%
Resources
The following resources are available for the Edimax Wi-Fi 150Mbps Mini USB Adapter
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Edimax
Price Range Ex VAT: 0 - 50
